how reprogram crimestopper?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20762
Printed Date: May 31, 2024 at 9:08 PM
Topic: how reprogram crimestopper?
Posted By: voltageGSR
Subject: how reprogram crimestopper?
Date Posted: October 30, 2003 at 11:45 AM
Hi own a remote start/sec crimestopper system. Installedit two years ago; worked great until car got damagedand ended up in the shop. battery was disconnected fora long while; and now whenever I reattach the mainwiring harness the alarm won't stop going off.the remotes don't seem to effect the alarm?I think the remotes may no longer be programmed for theunit. Anyone know how I can reprogram my crimestopperremotes? I tried there website; couldn't find anything.
thanks!
peace
Posted By: dangtong3
Date Posted: October 30, 2003 at 12:13 PM
What model is it? Each model has different programing steps
Posted By: jrilla
Date Posted: October 30, 2003 at 3:51 PM
This is a very typical sequence for many crimestopper models.
1. Open hood (ground the Gray hood pin wire if no hood pin is installed.)
2. Turn key to the ON position. (Doors will lock if Autolock is programmed)
3. Press Programming button 4 times, then after a few seconds the unit will flash the parking lights 4 times.
4. Press button #1 of the transmitter to be learned. You should get 2 light flashes indication the unit is waiting for a 2nd
code, then press button #1 of a second transmitter, the unit will flash 3 times indicating its waiting for the 3rd code and
lights will flash 4 times for 4th code. If all 4 codes are learned, the unit will automatically exit code learning mode,
otherwise turn key off and close hood. (See Diagram Below)
------------- J Rilla
Owner/Installer
Date Posted: October 31, 2003 at 1:28 PM
thanks! will try it and get back to you.
peace.
