2003 Hyundai Sonata Alarm/Remote Start/Stereo Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=20895
Printed Date: April 09, 2026 at 5:13 AM
Topic: 2003 Hyundai Sonata Alarm/Remote Start/Stereo Wiring
Posted By: yvonrichard
Subject: 2003 Hyundai Sonata Alarm/Remote Start/Stereo Wiring
Date Posted: November 02, 2003 at 4:09 PM
please i nedd wiring info to install a remote starter on a 2003 sonata with a transponder and a factory alarm ... thanks
Posted By: Javelin3o4
Date Posted: November 02, 2003 at 10:00 PM
This is the wiring for the 2002 maybe the same but make sure to check all connections first...
|              12V|red    (x2)         |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|orange              |+  |ignition harness            |
|        ACCESSORY|brown               |+  |ignition harness            |
|       POWER LOCK|lt. blue            |-  |16P plug, pin 11, rear of FB|
|     POWER UNLOCK|white               |-  |16P plug, pin 10, rear of FB|
|       LOCK MOTOR|gray                |   |16P plug, pin 12, rear of FB|
|     UNLOCK MOTOR|tan                 |   |16P plug, pin 6, rear of FB |
|    DISARM DEFEAT|no progressive unlck|   |                            |
| PARKING LIGHTS +|purple              |   |16P plug, pin 15, rear of FB|
| PARKING LIGHTS -|lt. blue            |   |light switch,steering column|
|       HEADLIGHTS|white               |-  |light switch,steering column|
|     DOOR TRIGGER|yellow              |-  |12P plug, pin 9, front of FB|
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|GREEN/ black         |-  |20 pin plug, pin 12 in DKP  |
|         HOOD PIN|lt. blue            |-  |12 pin plug, pin 2, ETACM *1|
|TRNK/HTCH RELEASE|green *2            |-  |12 pin plug, pin 5, ETACM *1|
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |-  |                            |
| DISARM NO UNLOCK|RED / blu or lt grn *6|+  |ignition harness            |
|       TACHOMETER|white               |   |instrument cluster or ECM *3|
|      SPEED SENSE|brown               |   |data link connector *4      |
|       BRAKE WIRE|lt. blue            |+  |brake pedal switch          |
|     HORN TRIGGER|yellow              |-  |steering column             |
|           WIPERS|green (L), purple(H)|-  |steering column             |
|  LF WINDOW UP/DN|blue - brown        |A  |driver window switch        |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |driver door harness         |
|  LR WINDOW UP/DN|green - purple      |A  |16 pin plug in DKP          |
|  RR WINDOW UP/DN|lt. green - purple  |A  |16 pin plug in DKP          |
| SUN RF OPN/CLOSE|yellow - yel/red    |A  |sunroof relay *5            |
|        RADIO 12V|orange              |+  |radio                       |
|     RADIO GROUND|BLACK/ orange        |-  |radio                       |
|     RADIO SWITCH|yellow              |+  |radio                       |
| RADIO ILLUMINATE|BROWN / white         |+  |radio                       |
|    POWER ANTENNA|gray                |+  |radio                       |
|       LF SPEAKER|tan - black         |   |radio                       |
|       RF SPEAKER|blue - red          |   |radio                       |
|       LR SPEAKER|white - brown       |   |radio                       |
|       RR SPEAKER|orange - green      |   |radio                       |
Notes:
*1 The ETACM (Electronic Time & Alarm Control Module) is attached to the fusebox below the fuses.  *2 Can also use blue (+) solenoid wire in the 16 pin plug, pin 7 in the driver kick panel. The fuel filler release is green (+) in the 20 pin plug, pin 15 in the driver kick panel.  *3 The ECM (Engine Control Module) is to the right of the accelerator pedal. On the 4 cyl models with A/T the tach wire is in the 26 pin plug, pin 3. 4 cyl models with M/T it is in the 12 pin plug, pin 8. 6 cyl models it is in the 40 pin plug, pin 17.   *4 The data link connector is under the steering column.  *5 Remove the front map light assembly and the relay is visible in the right side of the opening.  *6 This is the key sense wire for the ignition switch. Triggering this wire at the same time as both ignition wires will disarm the factory alarm without unlocking the doors.
