My Son has a 97 Civic HX. He purchased an ultrastart 430 alarm system off the internet. The instructions for installing are terrible and I have been unsuccessful in getting help from them. All he wants to do is install the dumb thing but does not know where to connect wires based on the info provided. Does anyone or has anyone out there installed a similar system into a civic that can help him out. Particularly how to hook up the keyless entry. He has everything mounted in the car already (siren, main module, valet switch, security light), just needs help with connecting up the harness to the right wires and location. Thanks
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V | white |+ |ignition harness |
| STARTER |BLACK/ white |+ |ignition harness |
| IGNITION |BLACK / YELLOW |+ |ignition harness |
| SECOND IGNITION|yellow |+ |ignition harness |
| ACCESSORY |WHITE/ black |+ |ignition harness |
| POWER LOCK |GREEN / WHITE |- |blue plug dkp or *2 |
| POWER UNLOCK|GREEN/ orange*3 |- |blue plug dkp or *2 |
| PARKING LIGHTS + |RED / black | |dkp/fuse box or *4 |
| PARKING LIGHTS - | | | |
| HEADLIGHTS |RED / wht(L)RED / blu(H) |+ |steering column |
| DOOR TRIGGER |lt. GREEN/ red*5 |- |factory alarm plug*2 |
| TRUNK/HATCH PIN |blue/blk*6 |- |dkp, harness to rear |
| HOOD PIN | | | |
|TRNK/HTCH RELEASE| | | |
| FCTRY ALARM ARM| | | |
|FCTRY ALRM DISARM| | | |
| TACHOMETER |blue | |test connector*1 |
| BRAKE WIRE |GREEN / WHITE |+ |brake switch |
| HORN TRIGGER |gray or blue |- |column or*2 |
| WIPERS |blue and blue / YELLOW |- |steering column |
| LF WINDOW UP/DN |RED / yellow - RED / blu|A |drivers door |
| RF WINDOW UP/DN |blue/yel - blue/org |A |drivers kick panel |
| LR WINDOW UP/DN |grn/yel - green |A |dkp, harness to rear |
| RR WINDOW UP/DN |yellow - yellow/grn |A |dkp, harness to rear |
Notes:
*1 Drivers side fire wall under hood. *2 Factory alarm plug located behind radio. (GREEN/ plug). *3 Can also use blue / YELLOW for driver door unlock only. *4 Male blade terminal at fuse box. Also at the back of the dimmer switch. *5 Can also be found in a light green plug above the fuse box or bottom of drivers kick, harness to rear. For dome supervision use lt. GREEN/ black at factory alarm/keyless plug. *6 Also available at factory alarm plug. (lt. green).
Use this to your discretion....i take no responsibility for the outcome of the install...but it shouldn't be too difficult...the spaces that are blank don't exist in the car. Good luck. If you have anymore question feel free to ask.
Does an HX model even have power locks? I always thought the DX and HX models come with manual locks. I have two diagrams for a 97 Civic. One of these will apply.
DIAGRAM 1
12volts white + ignition harness
Starter BLACK/ white + ignition harness
Ignition BLACK / YELLOW + ignition harness
Parking Lights+ RED / black dkp or fuse box or
Notes: Male blade connector at fuse box.
Door Trigger GREEN/ black - driver side A pillar
Trunk/Hatch Pin blue/black - dkp or fuse box
Notes: Two door hatch back does not have trunk pin.
dkp = drivers kick panel
DIAGRAM 2
Power Lock GREEN / WHITE - blue plug dkp or
Notes: Factory alarm plug located behind radio. (GREEN/ plug).
Power Unlock GREEN/ orange - blue plug dkp or
Notes: Can also use blue / YELLOW for driver door unlock only.
Parking Lights+ RED / black dkp/fuse box or
Notes: Male blade terminal at fuse box. Also at the back of the dimmer switch.
Door Trigger lt. GREEN/ red - factory alarm plug
Notes: Can also be found in a light green plug above the fuse box or bottom of drivers kick, harness to rear. For dome supervision use lt. GREEN/ black at factory alarm/keyless plug.
Trunk/Hatch Pin blue/blk - dkp, harness to rear
Notes: Also available at factory alarm plug. (lt. green).
I install Ultrastart remote starters every day, but have never dealt with their alarm units. If you have any specific questions, I'll download a manual and should be able to answer any questions you have.
