ok...sorry for the repost
there are 2 starter wires for nissans (black yellow and black white)....in my car they are both coming from the coil/harness to the key....the alarm i have has 1 wire to go the the starter key and 1 wire to go toward the starter coil, (this involves a cutt-off of the wires)....what do i do with the second starter..do i leave it attached to the key side and just tap the alarm starter wire to it...or do i cutt as well and do the same thing as i did for the first starter......i tried spliting up the 2 wires coming from my alarm into 4 to go to both starters and caused a check engine light...help..
If you are trying to install the starter disable relay then you have to cut both starter wires in order for the relay circuit to work properly. It will be the exact same as if you had one starter wire, but cut the other one and attach to the first wire. You do not need to split the 2 wires from the alarm to the starter wires rather you should connect the two wires that are cut on each side to each other and then attach it to the wires of the alarm. The alarm does have it's own relay insode of the module.... does it not ?? If it does then your doing it right, but if you require a relay then you need to go here : https://www.the12volt.com/relays/page2.asp#sk1
i am not trying to install a disable relay....i am merely trying to start the car....sorrry if i caused any confusion......the alarm is a CLIFFORD INTELLISTART G4 .
In that case you need to attach the Clifford G4 WHITE/ BLUE wire ( Starter wire in 9 pin harness ) to the Nissan starter wires like the way I said in the first reply on the other post. What you explained in this post above is the starter disable circuit where you have to have a key side and a starter motor side. You will NOT need to cut anything for this circuit to be working.
that clears a few things up....thanks...
No problemo
