Keyless entry on 2003 Taurus
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=23742
Printed Date: May 15, 2024 at 5:05 PM
Topic: Keyless entry on 2003 Taurus
Posted By: rwinter71
Subject: Keyless entry on 2003 Taurus
Date Posted: January 01, 2004 at 8:52 PM
I've just completed installing an Audiovox keyless entry on my 2003 Taurus.  All works great except the feature to AutoLock doors when car is started.  System option is enabled.  If I manually lock the doors, when I turn the car off the lock will unlock.  The only thing I wasn't sure about was the Door pin trigger.  Per note below I used the Yellow/Black on GEM to connect.  Could that be causing the problem possibly not sensing all the doors shut?
Notes: This wire controls the door ajar indicator on the dash, must cut the wire and diode isolate it from the instrument cluster. Can also use individual negative door trigger wires in the 26 pin plug at the GEM. They are: yellow/black (LF), gray/red (RF), lt. GREEN/ YELLOW (LR), and pink/lt. blue (RR).
Any help would be appreciated.
RW
Posted By: nighthawk2k
Date Posted: January 01, 2004 at 11:16 PM
on Ford Cars 7 trucks you have to wake up the gem module if you want to add an audiovox keyless entry unit.
Tommy
-Clifford/Directed/Alpine-Audio & Security-
New York Installerposted_image
Posted By: misterjimbo
Date Posted: January 02, 2004 at 1:00 AM
you can try the pos. trigger blk blue in the drivers kick, this is the dome light/all door trigger.
Date Posted: January 02, 2004 at 7:46 AM
Nighthawk2k - Not sure what you mean by "wake up the GEM"?  Is there a specific wire I need to tap for AutoLock to work?
Misterjimbo - Do you think the Blk/Blue wire will correct the autolock problem?  I believe I've identified that wire on the harness.
Thanks for your comments.
Posted By: draasch
Date Posted: January 02, 2004 at 8:02 AM
Make:   Ford
Model: Taurus
Year:    2003
This Database Was Last Updated On:    6/9/2003
Index #: 502
Alarm
Constant 12 volts LT.GREEN/ VIOLET IGNITION SWITCH HARNESS
Ignition 12 volts RED / LT.GREEN IGNITION SWITCH HARNESS
Starter RED / LT.BLUE IGNITION SWITCH HARNESS
Dome Light YELLOW (-) AT INTERIOR LIGHT
Trunk Pin Switch WHITE/ YELLOW (-) AT MODULE TO LEFT OF STEERING COLUMN
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock PINK / YELLOW DRIVERS KICK PANEL #201
Power Unlock PINK/GREEN DRIVERS KICK PANEL
#201 See Negative Pulse Door Lock Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: January 02, 2004 at 11:03 PM
Try this procedure to see if your car's doorlocks go to sleep
posted_image
Tommy
Date Posted: January 02, 2004 at 11:05 PM
posted_image
Tommy
Date Posted: January 02, 2004 at 11:06 PM
posted_image try this as well
Tommy
