Wire colors for 98 cherokee
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24059
Printed Date: May 23, 2024 at 1:52 PM
Topic: Wire colors for 98 cherokee
Posted By: danxav13
Subject: Wire colors for 98 cherokee
Date Posted: January 06, 2004 at 6:36 PM
Does any body have wiring info for a 98 regular jeep cherokee sport w/ factory keyless? My set of Omega books only goes up to 96 (last time I used them). I need to do a remote start and alarm . probably a clifford. Any help with colors and loctions of wires would be much appreciated. Thanks!!
Posted By: vaderfop
Date Posted: January 06, 2004 at 7:29 PM
12volts red & pink/black + ignition harness
Starter yellow + ignition harness
Ignition dark blue + ignition harness
Second Ignition BLACK/ orange + ignition harness
Accessory BLACK/ white + ignition harness
Power Lock ORANGE / purple - drivers kick panel
Power Unlock pink/purple - drivers kick panel
Parking Lights+ BLACK / YELLOW headlight switch
Door Trigger yellow - drivers kick
Trunk/Hatch Pin tied in with door
Tachometer gray AC black plug at PCM
Brake Wire WHITE/ tan + brake switch
------------- Remember check all your wires with a DMM!
Posted By: danxav13
Date Posted: January 07, 2004 at 6:03 AM
Thanks a bunch!! That should realy help me. Thanks again.
