2002 ram 1500 remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25123
Printed Date: June 11, 2024 at 2:04 AM
Topic: 2002 ram 1500 remote start
Posted By: roncoleman11
Subject: 2002 ram 1500 remote start
Date Posted: January 23, 2004 at 9:51 AM
Does anybody have a wire code for the truck. I am about to put a remote start on any tips on this, and window module
Posted By: tblanning
Date Posted: January 23, 2004 at 9:58 AM
Make: | Model: | Year: | Dodge | Ram Pickup | 2002-2003 |
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location | Start: | | YELLOW | IGNITION SWITCH HARNESS | Ignition #1: | | BLUE (16 AWG) | IGNITION SWITCH HARNESS | Ignition #2: | | RED | IGNITION SWITCH HARNESS | Ignition #3: | | GREEN & ORANGE (2 WIRES) | IGNITION SWITCH HARNESS | Accessory: | | BLACK/ WHITE & BLUE (2 WIRES) | IGNITION SWITCH HARNESS | Brake Light: | | WHITE/ TAN | AT SWITCH ABOVE BRAKE PEDAL | Tach Signal: | | TAN/RED | AT IGNITION COIL | Parking Lights: | | PURPLE / YELLOW | HEADLIGHT SWITCH* | Headlights: | | PURPLE / YELLOW | HEADLIGHT SWITCH * | Diesel Glow Plug: | | ORANGE / Black | Powertrain Control Module*** | Clutch Bypass Wire: | | |
| NOTES: * This Is A Single Wire System. Parking Lights Need To See A Ground (-) Through A 1.4 K-Ohm Resistor. Headlights Need To See A Ground (-) Through A 1.8 K-Ohm Resistor. ** Diesel Vehicles - ORANGE / Black Wait to Start; Tach Wire Is Gray/Black. Both Wires Are Located In A Black Connector Center Top Of Fire Wall. There Are Two Black Connectors, The Correct One Does Not Have A White Insert. *** Tach can also be located at pin 74 behind instrument cluster. |
Alarm and Keyless Entry Wiring Colors |
Function | | Vehicle Color | Location | Constant +12 Volts: | | PINK/BLACK | IGNITION SWITCH HARNESS | OEM Alarm Disarm: | | LT. GREEN/ ORANGE ***** | HARNESS COMING IN FROM DRIVER'S DOOR | Dome Lights/Superv: | | SEE NOTE *** | | OEM Horn: | | BLACK/ RED (-) | STEERING COLUMN HARNESS | Power Lock: | | WHITE/ GREEN | DRIVER'S KICK PANEL **** | Power Unlock: | | WHITE/ GREEN | DRIVER'S KICK PANEL **** | Trunk Release: | | N/A | | Alarm Input Wire: | | SEE NOTE *** | | NOTES: *** Separate Triggers For Each Door. The Driver's Door Trigger Is Tan (-). The Left Rear Door Trigger Is Tan/Orange (-). Both Wires Can Be Found In The Driver's Kick Panel. The Passenger Front Door Trigger Is Tan/Red (-) And the Passenger Rear Door Trigger Is Tan / YELLOW (-). Both Of These Wires Can Be Found In The Passenger Kick Panel. Diode Isolate Each Wire For Alarm Trigger With The Bands Facing Away From The Alarm/Remote Start Module. Use Only One Trigger For Dome Light Supervision. **** Single Wire Door Lock System See Note #211. Lock Requires A Ground (-) Pulse Through A 867 Ohm Resistor. Unlock Requires A Ground (-) Pulse Through A 364 Ohm Resistor. Diode Isolate One Of The Wires. ***** Requires A Negative Pulse Through A 1.5 K-Ohm Resistor. |
