1993 Silverado Door Lock Relay Location
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25455
Printed Date: June 10, 2024 at 11:23 AM
Topic: 1993 Silverado Door Lock Relay Location
Posted By: 1 pHAT z
Subject: 1993 Silverado Door Lock Relay Location
Date Posted: January 28, 2004 at 8:31 PM
Can someone tell me where I can find the power door lock relay in the dash,on a 1993 silverado pickup????THANKX!!!!
Posted By: geepherder
Date Posted: January 29, 2004 at 9:33 AM
It could be under the hood. Have a look and see. ------------- My ex once told me I have a perfect face for radio.
Posted By: HamiltonAudio
Date Posted: January 30, 2004 at 2:03 PM
does the truck have factory keyless entry? if not, its a reversal rest at ground circuit, and there are no relays (which is why you can't find them). I don't think that old a truck would have come with factory keyless as an option....if it has factory keyless, its a positive pulse circuit, and again no relays but rather triggered internally at the bcm... b
Posted By: defective
Date Posted: January 30, 2004 at 3:05 PM
ya... this truck didn't have the option of keyless...... so its a reversal rest at ground system, no relays -------------
Posted By: poboy12
Date Posted: February 09, 2004 at 3:27 PM
hello bud, i have almost the same question. i like to know where is the relays for my trucks power door locks located. i have a 99 ford f150 supercab. the locks work sometime or could it be in the switch can anyone help me?
------------- clemon
Posted By: sparkie
Date Posted: February 09, 2004 at 4:30 PM
Hi poboy12. The door lock/unlock circuit in your truck may be a negative trigger or 5 wire reversal rest at ground. The lock wire is pink / YELLOW and the unlock wire is pink/green. Both are found in the driver's kick panel. Test first to determine circuit type.
------------- sparky
Posted By: sroth140
Date Posted: February 10, 2004 at 2:34 PM
on the two door trucks it a 5 wire setup. youll need two relays or a DEI 415m. the colors are light blue (lock) and BLACK/ red (unlock). they are located in the drivers kick panel, or in the drivers door boot if you feel like messing with them there. the best thing to do is pull out all of the kick panel plastic and reach up through the little hole in the kick (there is a piece of metal before the main outer sheet of the chasis), there are a a few harnesses up there but you can dig and find the 5 wire one up there. coax it down out of the opening and you can wire it a little more out in the open rather than where you can barely reach it.
