would it hurt anything
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26438
Printed Date: June 03, 2024 at 9:41 AM
Topic: would it hurt anything
Posted By: shredder130
Subject: would it hurt anything
Date Posted: February 14, 2004 at 12:53 AM
would it hurt to add another siren to my alarm with out adding a relay, i have an extra DEI 514T sitting in my room from my old car thanks
Posted By: italnpimp59
Date Posted: February 14, 2004 at 12:58 AM
use a relay...if you dont, you stand a good chance at frying your alarm brain cause it doenst supply enough current to run two sirens.
Posted By: JWorm
Date Posted: February 14, 2004 at 1:08 AM
Any DEI system will handle two sirens fine. They can usually handle up to three without a relay.
Posted By: BangBang
Date Posted: February 14, 2004 at 1:11 AM
yeah do wat jworm saids its what i would have to agree on. we tried doing it to a motor bike and boy did it fry. so find out more info on the siren you have and plan on putting
Posted By: serialthrlla
Date Posted: February 14, 2004 at 1:12 AM
I ran two regular sirens and two piezo sirens off a clifford rs2 for like a year with no problems, but a relay is not that hard to hook up so might as well
Date Posted: February 14, 2004 at 1:35 AM
i have a bunch of extra 40/30 relays layin around, do you know where i could find the diagram to hook one up for this purpose. thanks
Posted By: daniel2002p
Date Posted: February 14, 2004 at 10:25 AM
use a realy, the brain only puts so much current out, and you really are not gainning a lot of volume, use a relay.
------------- 2005 Toyota Corolla S
1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: FullForce
Date Posted: February 14, 2004 at 9:18 PM
thanks
pin 87 to 12V
pin 86 to ground
pin 85 to siren output wire
pin 30 to siren(s)
Date Posted: February 14, 2004 at 9:51 PM
thanks
