TOYOTA 2004
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26974
Printed Date: June 08, 2024 at 10:24 AM
Topic: TOYOTA 2004
Posted By: POWER
Subject: TOYOTA 2004
Date Posted: February 22, 2004 at 4:47 PM
i want to know if you got any information of wire diagram for the toyota tundra 2004
------------- MASS
Posted By: diabloed
Date Posted: February 23, 2004 at 3:09 AM
WIRING INFORMATION - TOYOTA / TUNDRA / 2004 / Remote Start
12volts white (40A), WHITE/ red (30A) + ignition harness
Starter grn/blk (V6), blk/wht (V8) + ignition harness
Ignition BLACK/ red + ignition harness
Second Ignition BLACK / YELLOW + ignition harness
Accessory blue/red + ignition harness
Keysense pink/black - ignition harness or plug below fuses
Notes: Using the status output wire from the remote start to trigger this wire will disarm the alarm without unlocking the doors.
Power Lock WHITE/ green or GREEN/ black - driver kick or plug below fuses
Notes: Meter these wires while turning the key in the driver door key cylinder.
Power Unlock blue/red (double pulse) - driver kick or plug below fuses
Can also use the passenger key cylinder wire for unlock, which only requires a single pulse. It is RED / yellow or RED / white in the passenger kick or the plug below the fuses.
Parking Lights+ green + driver kick, harness to rear
Parking Lights- RED / black - headlight switch or plug below fuses
Door Trigger WHITE/ blue - driver kick, door harness
Dome Supervision use door trigger wire
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer black (V6), blue/white (V8) ac igniter (V6), ECM (V8)
Notes: On the V6 models, the igniter is on the passenger fender.
On the V8 models, the ECM is behind the glove box. The tach wire is in the far right plug, pin 5.
Brake Wire GREEN / WHITE + brake pedal switch
Horn Trigger GREEN/ red - column or plug below fuses
Posted By: diabloed
Date Posted: February 23, 2004 at 3:12 AM
WIRING INFORMATION - TOYOTA / TUNDRA DOUBLE CAB / 2004 / Remote Start
12volts wht/blu (40A), wht/red (25A) + ignition harness
Starter BLACK/ white + ignition harness
Accessory pink + ignition harness
Keysense YELLOW /GREEN - ign harn or BECU, right plug, pin 22
The BECU (Body ECU) is above the driver kick panel, towards the firewall.
Power Lock see DirectFax document 1070
Notes: The door lock wire colors are the same as those listed for the Sequoia on DirectFax document 1070.
Power Unlock see power lock notes
Lock Motor blue/red 5wi DKP or BECU, right plug, pin 1
Notes: The BECU (Body ECU) is above the driver kick panel, towards the firewall.
Unlock Motor RED / black 5wi DKP or BECU, right plug, pin 14
Parking Lights- green - switch or BECU, left plug, pin 14
Door Trigger blue/black - ignition key cylinder illumination
Notes: Can also use individual door trigger wires at the BECU. The LF door is gray/red, middle plug, pin 15. The RF door is lt. GREEN/ black, right plug, pin 8. The LR door is RED / white, middle plug, pin 16. The RR door is RED / white, right plug, pin 4. Use all four wires and diode isolate each.
Dome Supervision comes on with unlock
Hood Pin blue/white - pin sw. or BECU, left plug, pin 5
Tachometer WHITE/ blue ac ECM, right plug, pin 5
Notes: The ECM (Engine Control Module) is behind the glove box.
Horn Trigger BLACK / YELLOW - column or BECU, right plug, pin 21
