04 Scion Xb
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27769
Printed Date: May 04, 2024 at 12:22 PM
Topic: 04 Scion Xb
Posted By: skycivic
Subject: 04 Scion Xb
Date Posted: March 05, 2004 at 2:34 AM
I Just bought a Scion Xb and i have an Autopage rs850 for it. Does anyone have a wiring diagram for this car yet?
Posted By: rudbwoy69camaro
Date Posted: March 05, 2004 at 8:51 AM
MAKE : SCION | MODEL : XB | YEAR : 2004
12volts WHITE/ blue and WHITE/ red + ignition harness
Starter  black   +   ignition harness
Second Starter  N/A
Ignition  black   +   ignition harness
Second Ignition  BLACK / YELLOW   +   ignition harness
Third Ignition  N/A
Accessory  blue/red   +   ignition harness
Second Accessory  N/A
Keysense  yellow   -   ignition harness
Power Lock  blue/white   -   driver kick, 14 pin plug
Power Unlock  yellow/black   -   driver kick, 14 pin plug
Lock Motor  blue/orange   5wi  driver kick, 9 pin plug
Unlock Motor  YELLOW /GREEN   5wi  driver kick, 9 pin plug
Parking Lights+  green   +   headlight switch
Parking Lights-  N/A
Hazards  GREEN/ orange   -   hazard switch
Turn Signal(L)  GREEN/ black   +   top of fuse box, 13 pin plug
Turn Signal(R)  GREEN/ YELLOW   +   top of fuse box, 13 pin plug
Reverse Light  RED / black   +   top of fuse box, 9 pin plug
Door Trigger  RED / white   -   top of fuse box, 9 pin plug
Dome Supervision  use door trigger wire
Trunk/Hatch Pin  common with door trigger
Hood Pin  N/A
Trunk/Hatch Release  N/A
Power Sliding Door  N/A
Factory Alarm Arm  N/A
Factory Alarm Disarm  N/A
Disarm No Unlock  N/A
Tachometer  black   ac   data link connector, pin 9
Wait to start  N/A
Brake Wire  GREEN/ red   +   brake pedal switch
Parking Brake  black   -   parking brake switch
Horn Trigger  WHITE/ red   -   steering column
Memory Seat 1  N/A
Memory Seat 2  N/A
Memory Seat 3  N/A
Note for powerlock:
Meter these wires while turning the key in the driver door key cylinder.
Note for powerunlock:
Meter these wires while turning the key in the driver door key cylinder. Unlock requires a double pulse.
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/red (-) in the passenger kick in a 14 pin plug.
Note for Parking Lights+:
Also found at the top of the fuse box in a 13 pin plug.
Note for Tach:
The data link connector is below the fuse box.
Note for Brake wire:
Posted By: Thack79
Date Posted: March 05, 2004 at 8:57 AM
Nice car. Whats it retail??
Posted By: dickpeter
Date Posted: March 05, 2004 at 11:37 AM
14165 for a xb with a manual trans.
If you havent been goto www.scionlife.com
