First I need to see if this vehical has the transpoder key. I believe it does.. I have not seen the key yet. It does have the factory alarm. I am thinking of useing the 555G bypass. Can anyone tell me how to go about this. I have never done a transponder bypass before. By looking at the 555g I need a data wire. Ignition, and key sence does anyone know color codes or how to find these? Thanks alot.
Clay
Make: Buick
Model: Park Avenue
Year: 1997
Alarm
Constant 12 volts YELLOW & BLACK IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light WHITE (-) AT BODY CONTROL MODULE *
Trunk Pin Switch ORANGE / BLACK (-) AT LIGHT IN TRUNK
Parking Lamp BROWN (+) AT LAMP CONTROL MODULE **
Power Lock RED / BLACK AT SWITCH IN #201
Power Unlock ORANGE / BLACK DRIVER DOOR ***
* Body Control Module Is Located Behind Passenger Dash. WHITE (-) Wire Also Located In 16 Pin Connector Behind Driver Dash To Left Of Steering Column. ** Lamp Control Module Located Behind Driver Dash To Left Of Steering Column. GRAY/BLACK (-) Wire At Headlight Sw. Can Also Be Used For Parking Lights. *** CAUTION!! This Car Uses A Data Link Circuit For Power Door Locks. Must Access Door Lock Wires At Switch In Driver Door. See Tech Notes!!
View Diagrams
Accessories
Window Up D\ D BLUE P\ D BLUE D\ D BLUE P\ D BLUE @ EACH #211
Window Down F/ BROWN F/ BROWN R/ BROWN R/ BROWN MOTOR *
Ign Key Warn L GREEN (-) IGNITION SWITCH HARNESS
Trunk Release BLACK (-) AT TRUNK RELEASE SWITCH ** #230
OEM Horn BLACK (-) STEERING COLUMN HARNESS
Headlights WHITE (-) AT HEADLIGHT SWITCH
OEM Alarm Arm PASSIVE ARMING SYSTEM ***
OEM Alarm Disarm L GREEN (-) IN DRIVER DOOR AT DOOR MODULE
* CAUTION!! This Car Uses A Data Link Circuit For Power Windows. Must Access The Wire Colors Listed Above At Each Motor In Each Door. #211- See Reversal Rest At Ground Power Window Circuit Diagram. ** BLACK (-) Wire Also Located At Body Control Module Behind Passenger Dash. *** OEM Alarm Arms 30 Seconds After All Doors Are Closed. #230- See Negative Trunk Release Diagram.
View Diagrams
Remote Start
Tach Signal WHITE AT POWERTRAIN CONTROL MODULE (PCM) *
Ignition #2 WHITE IGN. SW. HARN. (POWERS PCM & BCM) **
Ignition #3 ORANGE IGNITION SWITCH HARN. (HEAT/AC) #239
Accessory BROWN IGNITION SWITCH HARNESS #235
Neutral Safety YELLOW (-) AT SWITCH ON DRIVER REAR OF TRANSAXLE
Brake Light L BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light L GREEN (+) AT REVERSE LAMP RELAY ***
Rear Window Defrost N/A DATA LINK CIRCUIT
CAUTION!!! See Tech Notes Before Installing A Remote Start On This Vehicle!!!! * Powertrain Control Module (PCM) Located On Driver Front Of Engine Compartment In Air Cleaner Housing. ** WHITE Wire Powers Powertrain Control Module (PCM) And Body Control Module (BCM) And Is Powered In "Run" And "Start" Positions. *** Reverse Lamp Relay Located In Bussed Electrical Center Behind Pass. Dash
#201- See Negative Pulse Door Lock Diagram. #235- See Powering Extra Ignitions Diagram. *****CAUTION***** SEE NOTE #239 BEFORE ATTEMPTING REMOTE START #239 See Immobilizer Bypass Circuit Diagram
https://www.wiringinstructions.com/239.htm-------------
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
So u must get the door lock wires from the switch You cant Get them from the drivers Kick?
im showing a part# DB-DLM-2 that is for the data link system....
look at this site and click on the data link....
https://www.caralarm.com/start.html-------------
Good Luck
David
Ace Security
813-376-9778
Tampa
Do u have a manual or any other info on this unit? Have you ever used one before?
i just used one on a 03 trailblazer....worked pretty good...i can get more info on monday for you..i have the sheet that came with the unit...
Good Luck
David
Ace Security
813-376-9778
Tampa
Ok thanks dave could u also post what features it handles and how it works in general. Will it bypass the GM transponder?
Thansk
Clay
