2001 Acura CL Type S alarm wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29237
Printed Date: May 05, 2024 at 4:47 PM
Topic: 2001 Acura CL Type S alarm wiring
Posted By: Krazzyborri
Subject: 2001 Acura CL Type S alarm wiring
Date Posted: March 29, 2004 at 9:20 AM
Does anyone have the Wiring Diagram for a 2001 Acura CL Type S?
Thanx
Posted By: cbag1
Date Posted: March 29, 2004 at 10:43 AM
DEI info:
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|        ACCESSORY|yellow              |+  |ignition harness            |
|       POWER LOCK|BLACK/ blue          |-  |passenger fuse box *1       |
|     POWER UNLOCK|orange              |-  |passenger fuse box *1       |
|       LOCK MOTOR|WHITE/ red           |   |drivers fuse box *2         |
|     UNLOCK MOTOR|yellow              |   |drivers fuse box *2         |
|    DISARM DEFEAT|lt. GREEN/ red       |   |passenger MUX module *3     |
| PARKING LIGHTS +|RED / black           |   |passenger kick panel        |
| PARKING LIGHTS -|RED / yellow          |   |left of steering column     |
|       HEADLIGHTS|blue/red            |-  |left of steering column     |
|     DOOR TRIGGER|BLACK/ white         |-  |passenger fuse box          |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|blue/green          |-  |drivers fuse box            |
|         HOOD PIN|yellow              |-  |passenger fuse box          |
|TRNK/HTCH RELEASE|white               |+  |passenger MUX module *3     |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|blue                |-  |drivers door key cylinder   |
|       TACHOMETER|blue                |   |drivers shock tower *4      |
|      SPEED SENSE|blue/white          |   |cruise control module *5    |
|       BRAKE WIRE|WHITE/ black         |+  |brake switch                |
|     HORN TRIGGER|lt. GREEN/ blue      |-  |steering column             |
|           WIPERS|blue & blue / YELLOW  |-  |left of steering column     |
|  LF WINDOW UP/DN|RED / blu - RED / yel   |A  |drivers window switch       |
|  RF WINDOW UP/DN|blu/yel - blu/wht   |A  |RF window switch            |
| SUN RF OPN/CLOSE|grn/yel - grn/red   |A  |relays left of fuse box     |
|        RADIO 12V|WHITE/ yellow        |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|WHITE/ red           |+  |radio                       |
| RADIO ILLUMINATE|RED / black           |+  |radio                       |
|       LF SPEAKER|blu/grn - gry/blk   |   |at speaker                  |
|       RF SPEAKER|RED / grn - brn/blk   |   |at speaker                  |
|       LR SPEAKER|blu/yel - gry/wht   |   |at speaker                  |
|       RR SPEAKER|RED / yel - brn/wht   |   |at speaker                  |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555H or 555U.  *1 Located in a green 20-pin connector. Use the key switch in the passenger door to test.  *2 Located in a green 18-pin connector.  *3 The passengers MUX module is located behind the glove box.    *4 In a 2-pin connector near the air intake on the drivers side shock tower.  *5 The cruise control module is to the right of the steering column.
goodluck
