ignition grinding
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30448
Printed Date: May 29, 2024 at 3:08 AM
Topic: ignition grinding
Posted By: dyer
Subject: ignition grinding
Date Posted: April 15, 2004 at 6:03 PM
Hey everyone...long time no talk. Ok I am putting a Valet 554R on a 2001 dodge ram without factory alarm. EVERYTHING is working great, except when i get in to turn the key after a remote start it grinds. Anybody have any ideas?? I have the wires hooked up according to the daigram available at www.designtech-intl.com. Thanks a lot in advance!
------------- Dyer
Posted By: jrilla
Date Posted: April 15, 2004 at 7:44 PM
Do you mean it grinds when you turn the key to start and the car is already running? or do you mean you just turn the key to the on position and it grinds. If you have an anti-grind relay, then cut it out and dont use it, Just remember not to turn the key to the start position after it has been remote started. I have had a lot of problems with Dodge vehicles and anti-grind relays so if they ever give me trouble I cut em out. If you have one installed, how do you have it wired?
------------- J Rilla
Owner/Installer
Posted By: dyer
Date Posted: April 15, 2004 at 10:35 PM
The starter grinds only if i turn it as if i were cranking the car.
------------- Dyer
Posted By: jrilla
Date Posted: April 16, 2004 at 3:28 PM
so did you cut the starter wire during the install and add an anti-grind relay? If you did, then you installed it wrong or it is a faulty relay or diode. If you didn't install a relay then everything works fine and you should simply not turn the key that far.
Owner/Installer
Posted By: JWorm
Date Posted: April 16, 2004 at 9:35 PM
Don't turn the key that far .
Posted By: auex
Date Posted: April 16, 2004 at 10:09 PM
I agree with both posts above me, either install a starter kill relay and make sure that the anti grind feature is on or don't turn the key that far.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
