2005 chrysler 300c
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30913
Printed Date: May 04, 2024 at 10:48 AM
Topic: 2005 chrysler 300c
Posted By: CrazyInstaller
Subject: 2005 chrysler 300c
Date Posted: April 23, 2004 at 1:40 PM
i am an technician at a dealership in florida and I am trying to find wiring for after market security for a 2005 chrysler 300c. anyone have a clue?
Posted By: jfk51502003
Date Posted: April 23, 2004 at 3:17 PM
12volts pink/black or red  +  ignition harness
Starter yellow  +  ignition harness
Ignition dk. blue/white  +  ignition harness
Power Lock WHITE/ green  +  back of fuse box
Notes: Lock requires a positive trigger thru a 2.7K (2700) ohm resistor. Unlock requires a positive trigger thru a 620 ohm resistor. MUST use relays.
Power Unlock same wire as power lock
Lock Motor orange  5wi BCM
Notes: The BCM (Body Control Module) is located on the left side of the dash with the junction block.
Unlock Motor dk. blue  5wi BCM
Disarm Defeat pink/black  5wi BCM
Parking Lights+ do not use
Parking Lights- yellow  -  headlight switch
Notes: Parking lights require a negative trigger thru a 110 ohm resistor. MUST use a relay.
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger tan and tan/red  -  BCM
Dome Supervision yellow  -  fuse box, brown or white plug
Trunk/Hatch Pin tan/black  -  driver kick panel
Hood Pin
Trunk/Hatch Release BLACK/ white  +  release switch
Power Sliding Door N/A
Factory Alarm Arm lt. GREEN/ orange  +  driver kick, door harness
Notes: Arm requires a positive trigger thru a 1.87K (1870) ohm resistor, this will also lock the doors. Disarm requires a positive trigger thru a 680 ohm resistor, if use double pulse this will also unlock the doors. MUST use relays.
Factory Alarm Disarm same wire as alarm arm
Disarm No Unlock see factory alarm disarm
Tachometer tan/stripe  ac  any ignition coil
Horn Trigger BLACK/ red  -  steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
posted_image
Immobilizer Bypass Module:Required: YesType: Sentry KeyPart #: 555C or 555U
Notes: Only vehicles with gray keys have the immobilizer.
posted_image
THIS IS ALL I HAVE...HOPE IT HELPS
