02 GMC crew-cab door lock problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32097
Printed Date: March 25, 2026 at 3:45 PM
Topic: 02 GMC crew-cab door lock problem
Posted By: x6369x
Subject: 02 GMC crew-cab door lock problem
Date Posted: May 13, 2004 at 11:12 AM
I've had my 02 GMC crew-cab for about 2.5 years and originally put in a Sidewinder remote start/alarm into it. About 3 months ago, I upgraded to the Viper 791XV 2-way remote start/alarm and it's been working perfectly.
I noticed this morning that only the driver's door will lock/unlock via the Viper remote. Also, only the driver's door will lock/unlock via either the driver and passenger door switches. The 3 other door locks (passenger front and both rear doors) have stopped working for some reason.
I've had no problems w/ the locks in over 2.5 years, and originally installed the alarm per a DEI tech sheet. I connected the positive door lock outputs of the alarm directly to the lt. blue (lock) and white (unlock) at the BCM. My thinking is that if one of the alarm wires came loose, that the door lock would stop functioning all together, but still work with the factory switches.
I'll probably look at it tonight, but I was wondering if anyone had any ideas on what to check.
Thanks in advance.
------------- Friends Don't Let Friends Bump Stock.
Posted By: draasch
Date Posted: May 13, 2004 at 11:27 AM
disconnect the door locks and see if it still does it.... ------------- Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
