98 malibu door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32150
Printed Date: March 25, 2026 at 6:54 PM
Topic: 98 malibu door locks
Posted By: paulstoy71
Subject: 98 malibu door locks
Date Posted: May 14, 2004 at 1:31 PM
i am having a problem installing remote start with alarm and keyless entry. i have everything done except for the door locks  could anyone please send a diagram on this its driving me crazy  ... thanks all in advance
Posted By: kgerry
Date Posted: May 14, 2004 at 1:49 PM
Blue & White in DKP... both +
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Date Posted: May 14, 2004 at 5:52 PM
thanks  i found the door lock wires just neet help relaying them and i was told i need to use a resistor as well any one have diagram on this ???
Posted By: CutDog504
Date Posted: May 15, 2004 at 12:45 AM
You dont need resistors. Depending on your alarm, you might be able to connect directly to the door lock wires. The doorlocks are positive pulse locks. If you alarm only has negative doorlock outputs, then you will need relays, if your alarm has alternating outputs, than you can connect them directly.
