98 Tahoe keyless entry problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32197
Printed Date: February 05, 2026 at 12:45 PM
Topic: 98 Tahoe keyless entry problem
Posted By: dirtk38
Subject: 98 Tahoe keyless entry problem
Date Posted: May 15, 2004 at 1:48 PM
I was recently replacing the alternator on my 1998 4-door tahoe and had the battery disconnected for about 24 hours. After I installed my rebuilt alternator and reconnected my recharged battery, the stock keyless entry system will not work whatsoever from any distance. It worked fine before i replaced alternator. Is there something I can reset to make it work again? Thanks for any suggestions.
------------- 1998 Four Door Chevrolet Tahoe
Posted By: italnpimp59
Date Posted: May 15, 2004 at 2:15 PM
you may have to get the remote reprogrammed to your vehicle. if you have the battery disconnected for that long, i think it loses its programming. take it to a GM dealer
Posted By: dirtk38
Date Posted: May 15, 2004 at 2:31 PM
Actually I just found a thing in my manual about it-- I should have checked there first. I resynchronized it by pressing the LOCK and UNLOCK buttons simultaneously for 5 seconds, and that worked. Thanks for help though!
