best car info database?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33442
Printed Date: May 31, 2024 at 8:58 PM
Topic: best car info database?
Posted By: losone
Subject: best car info database?
Date Posted: June 07, 2004 at 12:41 AM
What is the best source of info for new car wiring/disassembly? I know about techsoft for dei dealers but what so you non authorized installers use? Ive seen the omega cd. but not sure about the quality,,, I tried scosche's online library but it's pretty weak. I mainly need wiring codes for installing alarms & nav systems & i'm willing to pay for a good library. Thanks in advance
Posted By: kgerry
Date Posted: June 07, 2004 at 10:33 AM
Wire Magic.... i find it my best source of info you'll have to pay, but you get what you pay for !!
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: mxxmikexx
Date Posted: June 08, 2004 at 3:42 PM
i agree with kgerry, even tho the best is usually your own hands on experience.
Posted By: profuse007
Date Posted: June 08, 2004 at 5:38 PM
www.the12volt.com has more than enough info. they have the database of car 2000 and older. you can also search on the forum for the new cars up to 2004 that ppl have listed.
thus, the best database..... the12volt.com ------------- Houston,TX
Posted By: sroth140
Date Posted: June 09, 2004 at 1:25 AM
my wire database is my DMM.... and techsoft/directwire
------------- MECP certified installer
Posted By: deviousjoker
Date Posted: June 09, 2004 at 5:42 PM
I use some common sense.......DMM......and directwire
------------- First Class MECP Installer
Posted By: losone
Date Posted: June 20, 2004 at 12:01 PM
Thanks Guys! I just tires wiremagic's one week demo & found it to be rather weak.... Alot of the cars that I had in my brain already, that I checked on wiremagic were either inaccurate or they had you going a lot farhter than you need to go to find the wire(like under the hood when it's under the dash). A lot of the cars listed also are missing most of the info they brag about having. I find it to be not worth it for what they charge. Anybody here use the omega cd?? For less than $100, im thinking of giving it a try.
