2004 Xterra Alarm Wiring Diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33519
Printed Date: May 20, 2024 at 7:06 AM
Topic: 2004 Xterra Alarm Wiring Diagram
Posted By: gtchida
Subject: 2004 Xterra Alarm Wiring Diagram
Date Posted: June 08, 2004 at 1:22 PM
I did a search but could not find a wiring diagram for factory alarm and stereo on a 2004 Xterra. Anyone have anything??? Thanks, Gary
Posted By: Autoobsession
Date Posted: June 08, 2004 at 6:59 PM
What exactly are you trying to do? -------------
Posted By: gtchida
Date Posted: June 08, 2004 at 7:26 PM
Aftermarket alarm/RS and stereo.
Posted By: Cptbrainiac
Date Posted: June 08, 2004 at 9:40 PM
12volts
| green (40A)
| ignition harness
| Starter | BLACK / YELLOW | + | ignition harness | | Second Starter | GREEN/ YELLOW | + | ignition harness | | Ignition | BLACK/ white | + | ignition harness | | Second Ignition | N/A | | | | Third Ignition | N/A | | | | Accessory | RED / yellow | + | ignition harness | | Second Accessory | WHITE/ blue | + | ignition harness | | Keysense | WHITE/ green | + | ignition harness | | Power Lock | lt. GREEN/ red | - | SECU to right of column, pin 5 | | Power Unlock | brown | - | SECU to right of column, pin 4 | | Lock Motor | blue | 5wi | SECU to right of column, pin 54 | | Unlock Motor | GREEN / WHITE | 5wi | SECU to right of column, pin 55 | | Parking Lights+ | blue/red | + | headlight switch | | Parking Lights- | N/A | | | | Hazards | same as turn signal wires | | | | Turn Signal(L) | GREEN/ YELLOW | + | steering column | | Turn Signal(R) | GREEN/ red | + | steering column | | Reverse Light | yellow/red | + | passenger kick, harness to rear | | Door Trigger | see notes | - | SECU to right of column | | Dome Supervision | RED / black | - | SECU to right of column, pin 31 | | Trunk/Hatch Pin | common with rear door trigger | | | | Hood Pin | BLACK/ pink | - | SECU to right of column, pin 6 | | Trunk/Hatch Release | N/A | | | | Power Sliding Door | N/A | | | | Factory Alarm Arm | yellow | - | SECU to right of column, pin 11 | | Factory Alarm Disarm | yellow/red | - | SECU to right of column, pin 10 | | Disarm No Unlock | see factory alarm disarm | | | | Tachometer | pink/blue | ac | instrument cluster or ECM, pin 3 | | Wait to start | N/A | | | | Brake Wire | BROWN / red | + | brake pedal switch | | Parking Brake | yellow | - | parking brake switch | | Horn Trigger | lt. GREEN/ red | - | steering column | | Memory Seat 1 | N/A | | | | Memory Seat 2 | N/A | | | | Memory Seat 3 | N/A | | | NISSAN, XTERRA, 2004, TachometerThe ECM is located below the heater box to the right of the accelerator pedal, behind trim panel. The tach is in the top row, 2nd pin left of center of the plug. **** Ask me no questions and I'll tell you no lies. ------------- Bill
Date Posted: June 08, 2004 at 10:06 PM
If you need anything else, PM me.
------------- Bill
Posted By: GMC4x4Guy
Date Posted: July 30, 2004 at 5:28 PM
What's the SECU? Is this just the ECM? Also, what are the notes, the links don't work right.
------------- "Drive it like you stole it"
Posted By: gtchida
Date Posted: July 30, 2004 at 6:31 PM
SECU is the smart entrance control unit that controls door switches, locks and interior lights and is located to the right of the steering column. The ECM is under the console near the heater. Gary
Date Posted: July 31, 2004 at 3:51 AM
Thanks Gary. Any idea of what the notes are?
Posted By: gtchida
Date Posted: July 31, 2004 at 10:58 AM
What notes are you looking for?
Date Posted: July 31, 2004 at 6:07 PM
The note for the door trigger and the note for the tachometer. Is there something important other than check the tach for ac instead of dc? Thanks for the help.
Posted By: gtchida
Date Posted: July 31, 2004 at 11:19 PM
Door trigger... Notes: Vehicles without power door locks, the door trigger/dome light is RED / black in the driver kick, harness to rear.
Vehicles with power door locks, the driver door is GREEN/ red at the SECU, pin 1, the front passenger door is GREEN/ black at the SECU, pin 2, and the rear doors are RED / black at the SECU, pin 3. Use all three wires and diode isolate each. Tachometer... Notes: The ECM is located below the heater box to the right of the accelerator pedal, behind trim panel. The tach is in the top row, 2nd pin left of center of the plug. Not sure if you're doing locks but my advice is to use single lock relay set up and tie in to the following wires.. Power Lock | lt. GREEN/ red | - | SECU to right of column, pin 5 | Power Unlock | brown | - | SECU to right of column, pin 4 |
Let me know if you have questions. Gary
Date Posted: August 01, 2004 at 1:10 PM
Perfect, thanks again for the help
