AT problems after Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34188
Printed Date: May 15, 2024 at 10:19 AM
Topic: AT problems after Remote Start
Posted By: Chevy70
Subject: AT problems after Remote Start
Date Posted: June 19, 2004 at 1:37 PM
I have installed a PRO-5007 COMBO (https://7925.adahost.com/computer/index.html?loadfile=item14035.html) in my 95 chevy suburban 1500 6,5TD. I also connected the starterkill. My only problems with the inst. was the door trigger and lock/unlock. The car starts very nice! After a couple of days the car wont shift more than to the 2nd gear! I called the workshop and they told me to disconnect the - poles from the batts. a few minutes, then all back to normal. After a day or two it happens again. If i dont use the remote start, the problem is not there! Have anyone experienced this??? My guess is that there is only one accessory cable used from the alarm module (heater/ac) while the car has several. I still have the brown accessory cable and want to give power to something that has to do with the AT during remote start, but i'm not sure. Also the workshop could not get connected with the car to read out alarms etc. Could i have f***ed something up?? They used to read out before.. Also the ABS system comes with a warning, the brakes feels like i'm on ice before the lamp comes on. I did have a short circuit during installation, but fuses are made to be blown right? Please help someone..
Nissan X-Trail 2005 model 2.2 dCi. Compustar 2W900FM-AS
Posted By: profuse007
Date Posted: June 19, 2004 at 1:48 PM
first of all, most shop will give you at least 30 days warranty for anything goes wrong. therefor, you shouldnt mess w/ it to void your warranty.
***take it back to your installer and let him worry about it.
why? what if you tamper w/ it and things goes wrong and then the isntaller will blame it on you. at the end, the only person you can sue is yourself.....
Houston,TX
Posted By: draasch
Date Posted: June 19, 2004 at 1:51 PM
you dont have all of the ign. wire connected here is the door info and the door locks:
Make:   Chevrolet
Model: Suburban
Year:    1995
This Database Was Last Updated On:    4/7/2004
Index #: 3893
Alarm
Constant 12 volts RED AND RED IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light WHITE (-) AT PIN SWITCH OR COURTESY LIGHT *
Trunk Pin Switch PURPLE (-) AT ANY PIN SWITCH OR DOME LAMP SWITCH
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock LIGHT BLUE DRIVER KICK PANEL OR AT
Power Unlock WHITE RELAYS BESIDE GAS PEDAL #202
* If Equipped With Auxillary Lighting Option, Use PURPLE (-) Wire At Any Pin Switch Or At Dome Lamp Override Switch. Will Trigger Alarm Regardless Of Dome Lamp Switch Position. #202- See Positive Pulse Door Lock Diagram.
Remote Start
Tach Signal WHITE OR PURPLE / WHITE AT DISTRIBUTOR
Ignition #2 WHITE IGNITION SWITCH HARNESS
Ignition #3 ORANGE IGNITION SWITCH HARNESS * #216,#235
Accessory BROWN IGNITION SWITCH HARNESS
Neutral Safety YELLOW (-) @ SWITCH ON TOP OF STEERING COL. **
Brake Light WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light LIGHT GREEN (+) SWITCH ON TOP OF STEERING COLUMN
Rear Window Defrost
* WHITE Wire Must Be Powered For Remote Start Applications Or Transmission Will Not Shift Properly And "Check Engine" Light Will Stay On. ** Switch May Be Present But Not Wired. #216- See G.M. Extra Ignition Diagram. #235- See Powering Extra Ignitions Diagram * WHITE Wire Must Be Powered For Remote Start Applications Or Transmission Will Not Shift Properly And "Check Engine" Light Will Stay On.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: jfk51502003
Date Posted: June 19, 2004 at 2:41 PM
def. ignition wires...all must be powered up...
Posted By: auex
Date Posted: June 19, 2004 at 7:14 PM
Yup, second and third ignition. This is common if you don't hook these wires up.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Chevy70
Date Posted: June 20, 2004 at 4:00 AM
Thanx all of you, now i have to try this, will get back with result.. thanx again!!
Posted By: Chevy70
Date Posted: July 17, 2004 at 4:00 PM
It worked FINE!! many thanks!!
