code alarm remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34480
Printed Date: June 12, 2024 at 8:57 PM
Topic: code alarm remote start
Posted By: zacman
Subject: code alarm remote start
Date Posted: June 24, 2004 at 5:39 AM
hi all i have a code alarm but not sure what model. it says its a sure start rvs if that helps. i got this car (1996 cutlass suprem 4 dr) that came with this alarm but it wont start every thing is hook up all but one orange wire can someone help. this is the fcc id _ goh-csm4.
Posted By: NowYaKnow
Date Posted: June 24, 2004 at 6:05 AM
If it doesn't start, what DOES it do? Lights flash? Horn honk? Ignition turn on? anything?
Mike
Posted By: zacman
Date Posted: June 24, 2004 at 6:29 AM
sorry all it does is flash lights when i hit the start button
Posted By: jfk51502003
Date Posted: June 24, 2004 at 5:19 PM
how many times does it flash...sounds like you either need to get tach...or turn on tach-less feature...the flashes usually are a diagnostic...each # of flashes represents certain features...
Posted By: zacman
Date Posted: June 25, 2004 at 3:10 AM
the lights on the car flash 2 times. and the tach is hook up.
Date Posted: June 25, 2004 at 5:40 AM
Two times on a code alarm usually means that it is in valet mode. Also, check the hood pin if one is installed.
Mike
Posted By: zacman
Date Posted: June 25, 2004 at 6:31 AM
i have not seen ahood pin nor a wire for one. dont know how to get out of valet mode dont even know if it has one i check all around and cant find a button for it
Posted By: zacman
Date Posted: June 25, 2004 at 7:10 AM
ok so i know have gotten the remote start to work but now i have to find out how to hook up the brake cut off and the starter grinds when i remote start .
