530T - One button up+down for both windws
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34494
Printed Date: May 15, 2024 at 11:42 AM
Topic: 530T - One button up+down for both windws
Posted By: Derekc
Subject: 530T - One button up+down for both windws
Date Posted: June 24, 2004 at 9:34 AM
I have a 530T installed and my channel 5 button is assigned to roll down both front windows. But when both windows are down, I have to get into the car and turn on the ignition and roll them up using the door buttons.  This is because no other channel from my alarm is available to tie to the 530T rollup wire. That rollup wire is now left unused.
Anyway to use the same channel 5 button to ROLL UP the windows? What I mean is if there is a "ground when window down" wire to drive a relay between the 530T and the channel 5 wire so that that same channel 5 button wire will send signal to the 530T rollup wire to roll up the windows?
I have a 2001 Odyssey honda and I looked at the circuit diagram in my service manual and I don't seem to find a "ground when window down" wire or anything similar to tell windows are down. Any idea how this could be accomplished?
DC
DC
Posted By: ka3vvv
Date Posted: June 24, 2004 at 10:11 AM
it ez with ground with arm to go up. use channal 5 to go down. it  your ch 5. can be splt you can do it exp press 2 times or if you can hold ove sce to actvi other - out put wire. now dei have way to do that with relay but need to look for that peoer work. there a way think you need 2 relays in some type of delay.
Posted By: Derekc
Date Posted: June 24, 2004 at 10:17 AM
Ka3vvv, I can't understand. Can you please rewrite?
DC
Posted By: ka3vvv
Date Posted: June 25, 2004 at 12:32 AM
use chan 5 to roll down your window.
use ground with armed to roll up your window. that should be a wire coming from yor alarm that put out a neg when your set your alarm. it will roll up your window.
you don't need a chan.
Posted By: Derekc
Date Posted: June 25, 2004 at 2:13 PM
That is right. Thanks.
DC
Posted By: CutlassThunder
Date Posted: June 25, 2004 at 11:34 PM
where can I get one of those modules for not to much I can't find them on ebay
Posted By: auex
Date Posted: June 26, 2004 at 12:29 AM
Look for "window module". I found 45 of them in about 3 seconds.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: dei user
Date Posted: June 26, 2004 at 1:01 AM
on the 530 t u should have a wire that says groung when armed or something like that. the wire the orange wire that is coming from the alarm u have to cut in half and the half that is on top u connect that wire together that is asking for ground and then put a device called a diode that u can get at your local radio shack and put one end of the dioe with the two wires u put together and the bottom part of the wire u cut the other end of the diode.but u have to get multimeter and read in which the current flows on the diode. so that way the ground that the relay is getting to kill your starter when alarm goes of gets still fed and the windows goes up.in other words u can put your windows up when u activate your alarm
dei user
Posted By: ka3vvv
Date Posted: June 26, 2004 at 1:43 AM
 The line side of the diode only let NEG flow throw. Take the line side in point to the Orange. You don't have to cut in haft. just bear some of the wire back .yep when you activate your alarm windows go up.
Posted By: ka3vvv
