Safe to completely remove stock alarm?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34863
Printed Date: May 15, 2024 at 11:07 AM
Topic: Safe to completely remove stock alarm?
Posted By: Ashez
Subject: Safe to completely remove stock alarm?
Date Posted: June 30, 2004 at 5:29 PM
Is it safe to completely remove a stock alarm? The car being a 2004 Civic, and the alarm is the KARR 4040A. The reason why I want to remove it is to put in a higher end alarm, the Delta FM 2005. I tried to add a CrimeStopper RS900VI to the KARR 4040A, but I ran into too many problems, so I just finalized that Id put in this Delta alarm... IF its safe to remove the stock KARR alarm. Thanks in advance!
Posted By: aidipf
Date Posted: July 01, 2004 at 12:33 PM
there is no reason to take out your factory alarm. in some cars it's not even possible, newer cars at least. all you have to do is disable your factory alarm. i'm not familiar with your typew of car but you usually just have to constantly ground the disarm wire. you can look up your vehicle's wiring diagram on the site though. good luck.
------------- MR. INNOVATIONS
Posted By: jfk51502003
Date Posted: July 01, 2004 at 1:51 PM
hey ashez...the karr alarm is not factory ...it is an after-market add-on...i use to install karr 2040/4040...sure...you can take that unit out ...everything is attached w/ t-taps and male spades ....right...? by the way are you in cali...?
Posted By: auex
Date Posted: July 01, 2004 at 7:51 PM
Yeah, Karr is aftermarket dealer add-on, not factory.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Ashez
Date Posted: July 02, 2004 at 5:12 PM
The car is a 2004 Civic, and the reason to take it out is to install a new LCD alarm. Im in the bay area..
