Hello all. I have a Voice Mod that needs to be reinstalled. However after all the time I don't have the wiring Diagram anymore. Also if I remember correctly I don't have the right wiring harness for the unit. so colors will not work. So if you have the Wiring Diagram and would like to help me out here is the colors I have for my harness. From left to right. Pin 1Red, Pin 2 Green, Pin 3 White, Pin 4 Yellow, Pin 5 Blue, Pin 6 Orange, Pin 7 Purple, Pin 8 Grey, Pin 9 Black. If I remember I got the harness from a Crimestopper Alarm so the colors will not be right from the manual. I used to have the pinout for the Mod however it was from an Old Fax Machine with Heat Transfer Paper now all I can make out is 516T Auto Security System Wiring the rest of the paper is now black :( Any help would be great. Thanks.
TanZ2004
Washington State
Bump Anyone have any informaiton? Thanks
TanZ2004
Washington State
From left to right. Pin 1Red, constant 12v (fuse it)
Pin 2 Green, dont use
Pin 3 White, connect to trigger wire of whatever shock sensor you are usin
Pin 4 Yellow, ignition
Pin 5 Blue, dont use
Pin 6 Orange, connect to (-) ground when armed output of alarm
Pin 7 Purple, ? i think the speaker for the 516t
Pin 8 Grey, ? same as above
Pin 9 Black ground
Thats assuming you got the right harness. If you can, email me a pic of the 516t, cause I have a 516t also in my car. If we have the same modules, then I'll give you the diagram that Im using for mine. BTW, you'll need a special speaker for this I believe
I am sure the Harness is not the right one However I am not sure if I changed the wires around to match the right diagram or not. You can email me the Diagram at jdanein@aol.com if you can scan a copy for me. Right now my Camera is with my Car in Idaho with my brother or I would send you a picture if the Unit. My scanner did not do a good job with the scan of the unit. Thanks for all the Help
TanZ2004
Washington
TanZ2004
Washington State
