Power Lock GREEN/ YELLOW DRIVER KICK * #201
Power Unlock GREEN PANEL *
#201 See Negative Door Lock Circuit Diagram * These Wires Can ALso Be Found At Theft Deterrent And Door Lock Control Unit (TDDLC) Located Behind Driver Dash, Above Fuse/Relay Block. At This Location GREEN/ YELLOW Will Lock & Arm, GREEN / WHITE Will Unlock & Disarm. TDDLC Unit Can Be Dropped After Removing Two Bolts (One Hidden).
most alarms that use the orange wire for starter disable, is for the - when armed output....which pin is it going to on the relay????
Trunk Release BLUE (-) AT TRUNK RELEASE SWITCH #230
some alarms have a strong enough output to go stright to the release wire..not sure about yours, i would just add a relay as yu stated....as lond as the output wire is a - output...put a fuse on pin 86..min 10 amp..
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
on the pyton the orange wire is ground when armed and should just connect to the orange wire on the alarm brain, the yellow wire on the starter kill will go to ignition .
Trunk release - as long as its neg trigger , fuse it as draasch said, 85 neg channel 2 out put, 86 12 volts constant, 87 ground , 30 to trunk release wire. make sure this is a neg trigger not a 5 wire as some are.
good luck
InstallerNY99
Thanks everyone. Sorry for the late reply we just got hit with hurricane Charley it was not pretty.
As always I thankyou for your help and will attempt to do this early next week. Thanks again!
Sound Pressure
Alarm is done. Thanks to everyone that helped. The funny thing is that this car came alive. My friend does not have the original remote for the factory alarm and lights and horns were going off. There were lights that were turning on that he did not know he had. It was to funny. Oh and very uncomfortable to work in and under that dash!
Sound Pressure
