Wiring question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=37723
Printed Date: February 02, 2026 at 8:34 PM
Topic: Wiring question
Posted By: johngianni
Subject: Wiring question
Date Posted: August 19, 2004 at 9:18 AM
I am installing RKE in a Dodge intrepid.. I have one question about the relays. In some documentation 30 is used for the output and 87 is used for the Ground or the +12. Then in some of the drawings on this site I have seen 30 as the Ground or +12 and 87 is used for the output.
Since 30 is the common connection of the switch and 87 is the closed connection it doesn't seem to me that it would matter once the switch is actuated.. I just want to make sure..
Thanks..
JohnG
Posted By: raydawg357
Date Posted: August 19, 2004 at 10:36 AM
What are you trying to do?
Do it right the first time
Date Posted: August 19, 2004 at 11:08 AM
OK..
1.) one relay is for a trunk release - trigger from RKE and trunk release is + trigger.
2.) door unlocks 2 relays, - trigger from RKE to + trigger 1 wire unlock/lock (with resistors)
3.) parking lights + trigger from RKE to - trigger for lights.
When I drew this up, I used 30 for all outputs and 87 for Ground (#3) and +12 (#1 and #2)
JohnG
