790 and 791xv - Prog codes same?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=38589
Printed Date: May 13, 2024 at 10:00 PM
Topic: 790 and 791xv - Prog codes same?
Posted By: MBZ oe
Subject: 790 and 791xv - Prog codes same?
Date Posted: September 04, 2004 at 4:50 PM
Hey. First, can anyone find the link for the 790xv install manual because a friend needs it and can't find his anymore. Second, Are the programming codes the same for 790 and 791? Like the RS3.5 is the same as 791? Thanks ------------- BOOM, BOOM, BOOM BOOM....
Posted By: auex
Date Posted: September 04, 2004 at 5:06 PM
I bet if you did a search you would find both the manuals for the alarm.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: MBZ oe
Date Posted: September 04, 2004 at 9:30 PM
I did a search but you know how DEI doesn't want people messing with the alarms so they took the direct link off the website to the install manuals. BUT, someone sent me a link for the 791 a while back, after the pulled link, that worked. So I have a 791 manual for him, if the programming codes are the same. We just need to change his engine cranking time and shut off the Theft Enhancing Circuit, I mean the Nuissance Prevention Circuit..... ------------- BOOM, BOOM, BOOM BOOM....
Posted By: Autosexual
Date Posted: September 04, 2004 at 11:08 PM
I have an 791xv install manual, if they are the same I will mail one to you.
Posted By: RufNUSD
Date Posted: September 04, 2004 at 11:35 PM
You must be a dealer to access www.directechs.com
------------- Someone pass me that bottle.
Posted By: auex
Date Posted: September 05, 2004 at 1:12 AM
790791------------- Certified Security Specialist
Posted By: MBZ oe
Date Posted: September 05, 2004 at 2:17 PM
Thanks AUEX. ------------- BOOM, BOOM, BOOM BOOM....
Posted By: kgerry
Date Posted: September 06, 2004 at 9:54 AM
and to answer your question, yes the programming is identical......
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
