89 Civic Shaved door solenioids
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39843
Printed Date: June 08, 2024 at 7:03 PM
Topic: 89 Civic Shaved door solenioids
Posted By: customcarelectr
Subject: 89 Civic Shaved door solenioids
Date Posted: September 27, 2004 at 12:42 PM
Im installing shaved door motors and poppers on an 89 civic hatchback.
I used regular door lock actuators (which I curretnly use everyday on my 75 coupe de ville 300 pound doors)
these actuators work great on the civic with the door open but when i close it up to test the whole setup the actuator does not seem to have enough torque to overcomethe added pressure on the latch.
I also tried one of the trunk release kit solenoids. same problem except way worse.
now i though i would just order some of the huge 35lb solenoids but  i look at the specs and the oly have 5.8" travel versus the 3/4" to 1" travel of the door lock actuators.
im sure many people have successfully oped civic doors so whats the trick? what am i overlooking here?
thanks,
J
Posted By: mo12v
Date Posted: September 27, 2004 at 3:14 PM
Is that on ALL Doors?
Have U tried the motors without the "poppers"?
I have had doors where the rubber seal was enough to "Pop" the door
MO
Posted By: auex
Date Posted: September 27, 2004 at 9:30 PM
Door lock actuators will pull 12 lbs, trunk solenoids will pull 8 lbs, and door solenoides usually are 35+, stats are per DEI equiptment and are approx. What you need is the 35 pounders. The through isn't so much as important as the ability to pull. I used the 35 lbs solenoids succesfully on my civic when the handles were shaved, but niether the actuators or trunk pop soleniods wouldn't do the trick.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: September 28, 2004 at 3:23 PM
Thanks Mo12, that s a good idea, i havd had the same experience. Ill try that as wel.
Auex: did you hook the 35 lb directly tot the door pull as usuall? only reaosn i ask is because of the throw on the solenoid.
where did you fit that on the civic door? Im assuming you had to do some sheetmetal surgery on the inner door skin?
thanks
Posted By: auex
Date Posted: September 28, 2004 at 6:57 PM
I hooked it up to the rod going to the inner door handle. I didn't have to do any surgery.
Posted By: Esco1977
Date Posted: September 29, 2004 at 9:12 PM
i have allways used dei trunk solinoids on all my cars that i removed the handles in. usally i place them on the latch that was going to the outside handle. Allthough sometimes after install they might need a little ajustment in the tension and making sure the window can roll all the way down. hope this helps.. Ps ive had the same solinoids in my nissan for over 5 yrs now and still no problems  the part number is 552t
