2005 Altima
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40017
Printed Date: May 13, 2024 at 1:37 AM
Topic: 2005 Altima
Posted By: brianh
Subject: 2005 Altima
Date Posted: September 29, 2004 at 7:59 PM
I installed a R.S. unit on this car but I am having trouble getting the universal transponder bypass to work on this car. It seems when I try to position the ring on the key cylinder and dont have it in the right place,that the car will go into some kind of lock down mode and the keys wont work. Does anyone know what it takes to put it in this mode, or how to get it out? All I lack is the bypass and it is driving me crazy because it is so simple but I have no info on this new vehicle. Thanks in advance.
------------- Brian
owner/installer
Sight & Sound Car Stereo
"all electronic equipment runs off of smoke, once you let it out, it stops working"
Posted By: mo12v
Date Posted: September 29, 2004 at 8:29 PM
I think U still have to go to the Passenger door for the Window to Roll Up correctly when it has Auto Up/Down
------------- MO
Posted By: Velocity Motors
Date Posted: September 29, 2004 at 8:34 PM
??? Huh ------------- Jeff
Date Posted: September 29, 2004 at 8:36 PM
Brian, the Immobilizer system for the Nissan is just as picky as the Ford's. There is a sweet spot on the module that the key has to rest in and if it's outside of this, then the Nissan will lock you out becuase it thinks that your trying to jack the car. Make sure that the ring is tightly wound up by the ignition cylinder and same goes for the key inside the module, make sure there isn't room for the key to move to slip outside of the sweet spot.
------------- Jeff
Posted By: mo12v
Date Posted: September 29, 2004 at 9:28 PM
I gotta stop drinking...Wrong Post...Sorry
------------- MO
