2004 Hyundai Tiburon
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41968
Printed Date: May 02, 2024 at 4:48 PM
Topic: 2004 Hyundai Tiburon
Posted By: iskidoo
Subject: 2004 Hyundai Tiburon
Date Posted: October 31, 2004 at 10:44 AM
Can someone please post the wiring diagram for a 2004 Tiburon. thanks
Posted By: Teken
Date Posted: October 31, 2004 at 12:25 PM
TIBURON 2003-2004
WIRE COLORS LOCATION
12 VOLTS CONSTANT RED (+) IGNITION SWITCH HARNESS
IGNITION 1 RED (+) IGNITION SWITCH HARNESS
IGNITION 2 IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 1 PINK (+) IGNITION SWITCH HARNESS
STARTER WHITE (+) IGNITION SWITCH HARNESS
PARKING LIGHTS ( + ) PINK/BLACK (Left) GREEN/ ORANGE (Right) 22 PIN PLUG AT BCM (Body Control Module) at the FUSE BOX UNDER DRIVERS DASH
DOME LIGHT YELLOW (-) 22 PIN PLUG AT BCM
DOOR TRIGGER
POWER DOOR LOCK YELLOW or BLUE 12 PIN PLUG AT BCM (TYPE "F")
POWER DOOR UNLOCK YELLOW or BLUE 12 PIN PLUG AT BCM (TYPE "F") SEE NOTES BELOW
TACH SENSOR WHITE 23 PIN PLUG IN PASSENGER KICK PANEL
BRAKE
WHITE (+) AT BRAKE SWITCH
HORN GREEN/ BLACK (-) AT STEERING COLUMN HARNESS
ALARM DISARM
ANTI-THEFT TRANSPONDER Requires #791 bypass
NOTES: The POWER DOOR LOCKS ARE A TYPE "F" system, this will require part # 775 relay. See attachment for the wiring of the #775 RELAY.
------------- Knowledge is power. But only if you apply that knowledge in a positive way, which promotes positive results in others.
EVIL Teken . . .
Posted By: Teken
Date Posted: October 31, 2004 at 12:27 PM
DIRECTWIRE™ WIRING INFORMATION - HYUNDAI / TIBURON / 2003 / Remote Start
12volts red + ignition harness
Starter white + ignition harness
Second Starter N/A
Ignition red + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory pink + ignition harness
Second Accessory orange + ignition harness
Keysense blue/orange - ignition harness
Power Lock yellow or blue F 12 pin plug @ BCM
Notes: The yellow wire will test when moving the driver lock knob, the blue wire will test when moving the passenger lock knob.
The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash.
Power Unlock same wire as power lock
Lock Motor green 5wi 22 pin plug @ BCM
Notes: The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash.
Unlock Motor GREEN/ black 5wi 22 pin plug @ BCM
Parking Lights+ pnk/blk (L), grn/org (R) + 22 pin plug @ BCM
Parking Lights- blue/orange - headlight switch
Hazards white - hazard switch
Turn Signal(L) yellow/black - steering column
Turn Signal(R) blue/black - steering column
Reverse Light gray + 22 pin plug @ BCM
Door Trigger yellow - 22 pin plug @ BCM
Dome Supervision use door trigger
Trunk/Hatch Pin GREEN/ black - 12 pin plug @ BCM
Hood Pin GREEN/ orange - 23 pin plug @ BCM
Trunk/Hatch Release blue + driver kick panel
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer white ac 23 pin plug in pass. kick
Wait to start N/A
Brake Wire white + brake pedal switch
Parking Brake blue/black - 15 pin plug in driver kick
Horn Trigger GREEN/ black - steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 556U or 555U
Notes: N/A
EVIL Teken . . .
Posted By: Teken
Date Posted: October 31, 2004 at 12:30 PM
Make: Hyundai
Model: Tiburon
Year: 2003
This Database Was Last Updated On: 9/16/2004
Index #: 5297
Alarm
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts RED IGNITION SWITCH HARNESS
Starter WHITE IGNITION SWITCH HARNESS
Dome Light YELLOW (-) 22 PIN PLUG AT BCM
Trunk Pin Switch GREEN/ BLACK (-) DRIVERS KICK PANEL
Parking Lamp BLUE/ORANGE (-) AT HEADLIGHT SWITCH
Power Lock YELLOW 12 PIN PLUG AT BCM * #206
Power Unlock BLUE 12 PIN PLUG AT BCM #201
* Must Use A SPDT Relay To Break YELLLOW Lock Wire To Lock Doors NOTE:Follow diagram except where the blue wire from the dlpn3 is connected to pin 30. Do not connect it there.Connect it to the blue wire at 12 pin connector. Information Courtesy Of Installer!! Any AdditionalInformation Appreciated!!
View Diagrams
Accessories
Window Up
Window Down
Ign Key Warn
Trunk Release BLUE (+) DRIVERS KICK PANEL
OEM Horn GREEN/ BLACK (-) STEERING COLUMN
Headlights
OEM Alarm Arm
OEM Alarm Disarm
OEM Hood Pin:GREEN/ ORANGE (-) Located In A 23 Pin Plug In Passigner Kick.
View Diagrams
Remote Start
Tach Signal WHITE LOCATED IN A 23 PIN PLUG PASS KICK
Ignition #2 ORANGE IGNITION SWITCH HARNESS
Ignition #3
Accessory BROWN IGNITION SWITCH HARNESS
Neutral Safety
Brake Light WHITE (+) AT BRAKE SWITCH
Reverse Light
Rear Window Defrost
View Diagrams
EVIL Teken . . .
Posted By: iskidoo
Thanks, Teken
What is a good reliable Manual transmission compatible (with reservation mode) keyless/starter brand that you guys install?
Posted By: iskidoo
Date Posted: October 31, 2004 at 12:33 PM
I've been looking at DirectStart CS524, UltraStart manual models and would like some ideas on some other reliable brands. Although I've heard Ultrastarts can be finicky and tempermental.
Posted By: johnnydi77
Date Posted: October 31, 2004 at 6:46 PM
I install manual ultrastarts all the time and they work great. I like the way the go into ready mode too. very userfriendly... the only draw back is that the programming sucks. Astrostart has revised their manual starters and I havent had a chance to install one yet but if they work as well as their automatic starters then they will be flawless
------------- John J. DiStefano Jr.
