rear window on remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42335
Printed Date: May 28, 2024 at 7:42 PM
Topic: rear window on remote start
Posted By: woeful
Subject: rear window on remote start
Date Posted: November 06, 2004 at 12:13 AM
hi, I did a search, but didn't found any, hope someone can help me with this, I need to know how to turn on the rear window defroster when remote start is activated, what wire do I need to connect to what wire, I have the c3000 compustar system, thanks
Posted By: slab42
Date Posted: November 07, 2004 at 9:41 PM
it all depends on the car's wiring. usually you can get the wire at the rear defrost switch, but some times you need to 5-wire it. you should just do some testing with a DMM on the switch, and use a negative status wire off the RS. I am not sure about the c3000, but it should have a wire that you use for a bypass module (like 555u,etc) use that to a relay to trigger the wire. I would 5-wire it just to be safe!
Posted By: audiopro111
Date Posted: November 08, 2004 at 1:10 AM
what kind of car and what year
------------- AudioPro111
Posted By: woeful
Date Posted: November 08, 2004 at 3:57 PM
my car is 98 integra, I am thinking of using one of the Aux wire and connecting it directly to the rear defrost wire, would that be ok? btw, would anyone know which wire is the defrost wire? I can not see all the way up to the defrost button, would anyone know where it would it be easier to reach? thanks
Date Posted: November 08, 2004 at 9:02 PM
you might not even have to connect that wire just make sure all your accesorie wires are powered up as well as your all of the ignition wires too.
