Alarm Input Wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=43390
Printed Date: April 17, 2026 at 8:42 AM
Topic: Alarm Input Wire
Posted By: realsynthetics
Subject: Alarm Input Wire
Date Posted: November 20, 2004 at 8:51 AM
Well, the last time I tried this, I applied forum codes, and it looked like heiroglyphics.
I was reading through wiring information for my car (1996 Intrepid) on this site and on others.  On the other website I checked (company that makes an alarm sold at my work), they provided a wiring diagram with something that the one on this site doesn't have.
On the diagram for the alarm/keyless entry there is a wire called, "Alarm Input Wire" and it is yellow(-).  It is the exact same wire as the dome lights/courtesy lights yellow(-) on the BCM.  What is the significance of this wire, and why is it not listed on this website. Thanks guys.
-Duncan
Posted By: mo12v
Date Posted: November 20, 2004 at 9:08 AM
There are many Wiring Diagrams available from many companies.  Some have ALL the information available at that time (when it was created), some have limited information.  All companies gather their information differently. Some from actual installs, some from Factory Manuals (which even they R sometimes wrong), some from Installers and some from all 3.
NO ONE guarantees that they are accurate.
That is why Installers will Research, Test, & Test.
Even this 1996 Intrepid wiring diagram below may not be accurate, and I have been using these for 20 years.
Alarm
Constant 12 voltsRED & PINK/BLACKIGNITION SWITCH HARNESS
Ignition 12 voltsD BLUEIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightYELLOW (-)AT PIN SWITCH OR COURTESY LIGHT *
Trunk Pin SwitchTAN/BLACK (-)DRIVER KICK PANEL (REAR BODY HARNESS)
Parking LampBLACK / YELLOW (+)AT HEADLIGHT SWITCH
Power LockORANGE / WHITEIN LT.BLU 12-PIN CONNECTOR
Power UnlockPINK/VIOLETON THE BACK OF FUSE BOX
* YELLOW (-) Wire Also Located At Body Control Module In Passenger Kick Panel Or In Connector Behind Fuse/Relay Block High In Driver Kick Panel. Positive Pulse Door Locks
Accessories
Window UpD\ L BLUE P\ BRN/WHT D\ BLU/WHT P\ GRY/BLK @ MAIN SWITCH
Window DownF/ WHITE F/ VIO/WHT R/ RED / BLK R/ GRN/WHT
Ign Key WarnL BLUE (-)IGNITION SWITCH HARNESS
Trunk ReleaseBLACK/ WHITE (+)AT TRUNK RELEASE SWITCH
OEM HornBLACK/ RED (-)STEERING COLUMN HARNESS
HeadlightsL GREEN (+)AT HEADLIGHT SWITCH
OEM Alarm ArmN/A
OEM Alarm DisarmL GREEN/ ORANGE (-)BLACK 16 PIN CONN. IN DR. KICK PANEL
Reversal Rest At Ground Power Window Circuit
Positive Pulse Trunk Release
Remote Start
Tach SignalRED, WHITE & BLACKAT COIL PACK ON TOP OF ENGINE *
Ignition #2RED / WHITEIGNITION SWITCH HARNESS **
Ignition #3BLACK/ ORANGEIGNITION SWITCH HARNESS **
AccessoryBLACK/ WHITEIGNITION SWITCH HARNESS
Neutral SafetyBLACK/ L GREEN (-)AT SWITCH ON DR. SIDE OF TRANSAXLE
Brake LightWHITE/ TAN (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightVIOLET/BLACK (+)AT FUSE BLOCK ***
Rear Window DefrostN/ATIMER BUILT INTO SWITCH
* Coil Pack Located On Top Of Passenger Side Of Engine. Each Wire Listed Is A 2 Cylinder Signal. ** RED / WHITE Powers Transmission Control Module, BLACK/ ORANGE Powers Heat/Ac. *** VIOLET/BLACK (+) Wire Located In 10 Pin Green Connector ON Back Of Fuse/ Junction Block Behind Driver Dash.
MO
