2000 camero r\s
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=43429
Printed Date: April 16, 2026 at 7:53 AM
Topic: 2000 camero r\s
Posted By: mobile1
Subject: 2000 camero r\s
Date Posted: November 20, 2004 at 9:04 PM
   my techsheet tells me the accy wire is orange. I'm not seeing one in there, and I know brown is an accy, but what about the orange wire?
sencond question is its a man. transmission. i know about all the safety procausions I need to take, but what I can't figure out is how to bypass the clutch. I've done it on a saturn, but all that consisted of was catching the starter after the clutch. This one's stumping me. any help would be appreciated.
Posted By: draasch
Date Posted: November 20, 2004 at 9:07 PM
Make:   Chevrolet
Model: Camaro, Z28
Year:    2000-02
Alarm
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light WHITE (-) AT BODY CONTROL MODULE *
Trunk Pin Switch ORANGE / BLACK (-) AT BODY CONTROL MODULE *
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock RED / BLACK AT 6 PIN GREEN CONNECTOR #228
Power Unlock ORG/BLK & GRY/BLK JUST A BOVE PASSENGERS KICK *
* Body Control Module (BCM) Is Located Behind The Passenger Dash. Please Note That There Are Two GRAY/BLACK Wires Located At The BCM. The Correct GRAY/BLACK Wire Is Located In A 32 Pin BLUE Connector Will Also Be found In Harness Running Under Passengers Dash And Will Show A (-) Ground When The Driver Door Is Opened. #228 - See Camaro/Firebird Door Lock Diagram.
Remote Start
Tach Signal WHITE AT POWERTRAIN CONTROL MODULE * #237
Ignition #2 ORANGE IGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3 N/A
Accessory BROWN IGNITION SWITCH HARNESS
Neutral Safety ORANGE / BLACK (-) AT SW. ON BASE OF GEAR SELECT SWITCH
Brake Light L BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light L GREEN (+) 10 PIN CONNECTOR IN PASS. KICK PANEL
Rear Window Defrost GRAY (+) AT REAR WINDOW DEFOGGER SWITCH
* Powertrain Control Module Is Located On Pasenger Rear Of Engine Compartment.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: mobile1
Date Posted: November 20, 2004 at 9:12 PM
what about bypassing the clutch????? at the clutch switch there are I believe 4 different wires that all test different, as well. None of them read 12v+ with the starter cranking and the clutch depressed
