Anybody dealt with Astrostart\Astroflex RS systems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=4424
Printed Date: May 25, 2024 at 3:31 AM
Topic: Anybody dealt with Astrostart\Astroflex RS systems
Posted By: gdesir
Subject: Anybody dealt with Astrostart\Astroflex RS systems
Date Posted: October 13, 2002 at 9:30 AM
I just bought the Astrostart / Astroflex 1105 and wanted to know is this a difficult system to install?  I heard it one of the best so i bought it.
Posted By: 12voltlover
Date Posted: October 14, 2002 at 7:25 PM
Unfortunately, the store I work at sells Astrostart.  It is a well made product but installation sucks !!!  If you are not familiar with remote starts it will be a nightmare.  I've been installing them for about a year now and it still takes twice as long to do than any other systems.  I've done DEI, Avital, Ungo, etc., for several years and they are so much simpler.  I do think the 1105 is the easiest of them to do but it still takes forever.  What kind of vehicle is it going in??  Good Luck !!
Posted By: gdesir
Date Posted: October 14, 2002 at 9:10 PM
2001 Nissan Altimma.  I'm just waiting for 5 relays that i ordered to come in then i will start this weekend.  I have put in a remote start before so i have a pretty much idea about what to expect.  It took me all weekend for that one so i expect the same time (if not more).  I know it will be hard, that's why i'm trying to get all the wire diagrams i can get my hands on.  Do you by any chance have access to the AstroChart?   I would sure appreciate it if you canget me all the info (including pics) about the wire diagram for my car.
TIA
Posted By: magoo_ns
Date Posted: October 18, 2002 at 8:58 PM
I have just bought a 1999 Dodge Caravan equipped with an Astroflex remote. I don't see a model number on it, but it has 6 buttons and a switch on the side.  It worked great for a week, but then the van refused to start with the key.  It would however start with the remote, but a small red light on the dash flashes continuously now.. At the same time, one brake light failed for no apparent reason.  I do not have the owners' manual for the remote system, so it's entirely possible that I accidentally armed something and can't figure out how to disarm it.
Can anyone help?
Posted By: Velocity Motors
Date Posted: October 19, 2002 at 10:02 PM
Here is the wiring information for the 2001 Altima:
|              12V|WHITE/ red           |+  |ignition harness            |
|          STARTER|BLACK / YELLOW        |+  |ignition harness            |
|   SECOND STARTER|BLACK/ blue          |+  |ignition harness            |
|         IGNITION|BLACK/ red           |+  |ignition harness            |
|        ACCESSORY|BLACK/ pink          |+  |ignition harness            |
| SECOND ACCESSORY|WHITE/ blue          |+  |ignition harness            |
|       POWER LOCK|gray                |-  |smart entrance control *1   |
|     POWER UNLOCK|purple              |-  |smart entrance control *1   |
|       LOCK MOTOR|RED / blue            |   |smart entrance control *1   |
|     UNLOCK MOTOR|yellow              |   |smart entrance control *1   |
|    DISARM DEFEAT|WHITE/ red           |   |smart entrance control *1   |
| PARKING LIGHTS +|RED / blue            |   |steering column             |
|       HEADLIGHTS|RED / yel(L),lt blu(R)|+  |steering column             |
|     DOOR TRIGGER|RED / white *3        |-  |drivers kick panel or SECU  |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|red or RED / blue     |-  |light in trunk              |
|         HOOD PIN|pink/black          |-  |smart entrance control *1   |
|TRNK/HTCH RELEASE|ORANGE / black        |-  |smart entrance control *1   |
|  FCTRY ALARM ARM|lt GREEN/ red        |-  |smart entrance control *1   |
|FCTRY ALRM DISARM|GREEN/ YELLOW        |-  |smart entrance control *1   |
|       TACHOMETER|WHITE/ black         |   |6 pin plug at distributor   |
|      SPEED SENSE|PURPLE / red          |   |ECM, pin 26 *2              |
|       BRAKE WIRE|RED / green           |+  |brake pedal switch          |
|     HORN TRIGGER|brown or grn/yel    |-  |steering column             |
|           WIPERS|lt grn/rd,lt grn/blk|-  |steering column (L, H)      |
|  LF WINDOW UP/DN|green - blue        |A  |drivers window switch       |
|  RF WINDOW UP/DN|RED / wht - RED / blk   |A  |drivers switch or kick panel|
|  LR WINDOW UP/DN|yel/red - yel/blk   |A  |drivers switch or kick panel|
|  RR WINDOW UP/DN|grn/wht - grn/blk   |A  |drivers switch or kick panel|
Notes:
NOTE: Some models have an immobilizer system  *1 The smart entrance control unit is located to the right of the steering column.  It is black or blue in color.  *2 The ECM is located in the front of the center console on the transmission hump. DO NOT UNPLUG THE ECM.  *3 To avoid dome light delay use RED / green for the driver door, red for the front passenger door, and RED / black for the rear doors. All 3 three wires are located at the smart entrance control unit. Must diode isolate each.
Date Posted: October 19, 2002 at 10:03 PM
magoo_ns : Check and replace the broken brake lamp bulb because this may be giving the system an error and not allowing you to start the vehicle with the key.
