wire instead of rods.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=44299
Printed Date: May 16, 2024 at 2:28 PM
Topic: wire instead of rods.
Posted By: OZzyd
Subject: wire instead of rods.
Date Posted: December 02, 2004 at 3:30 PM
hello all i need to add actuators to a new 2005 accord but instead of old rods like before it comes with the new design wire, is there any new actuators or way to make this work or do i have to rig something to make it happen?
Posted By: spl-Hz
Date Posted: December 02, 2004 at 4:08 PM
We installed actuators in a hyundai befor with wires and it's a pain in the a.. The customer would show up every couple of months to have them fix. We attached rods to the wire and after time the would come loose. Neadless to say we wouldn't attempt it again. One thing i might suggest is to super glue the attachment point.
Posted By: OZzyd
Date Posted: December 02, 2004 at 4:15 PM
i was thinking to connect the wire directly to the actuator and the rod to the stub in the door but i need to figure out a way to make both (rod and wire) attach to the actuator itself i need two wholes instead of one if u know what i mean
Posted By: jc18750
Date Posted: December 03, 2004 at 5:52 AM
i did a hyundai with cable locks. i put a couple of bends in the lock rod to get it where i wanted it. but in the end i had drilled a hole in the plastic behind the lock switch and bent a hook in the after market lock bar. it works fine and haven't had a problem with it yet, its been about a year. However, it was indeed a pain in the a.. and not worth the time and money.
Posted By: Dreadlock
Date Posted: December 03, 2004 at 4:27 PM
i have done it before but im with the others on this one the customer comes back about 3-4 times a year to have them fixed.
Posted By: DanDan
Date Posted: December 03, 2004 at 6:47 PM
This an easy one to do. Go to your local Honda dealer and order all 4 power door locks. They come with the latch assembly. They are kind of a pain to put in but after doing a ton of them it is now easy. The front doors are more difficult. I do not try to hack up the old ones as the factory parts are cheap. I think I pay like $15 for the rears per and $25 each for the front. The only mod you have to make is connecting the wires up to the actuators. I have never had one returned, they are factory! If you need the part numbers just ask.
DanDan
Posted By: NowYaKnow
Date Posted: December 04, 2004 at 1:21 AM
Most of the times with the cables instead of rods it is easier to attach your actuators directly to the lock button itself, or to the latch assembly itself. Factory parts as suggested isn't a bad idea either.
Mike
