i am looking for a schematic to install a valet model 561T remote start on a 2004 dodge ram any help will be greatly appreciated
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | Yellow | IGNITION SWITCH HARNESS* |
Ignition #1: | | Pink/White | IGNITION SWITCH HARNESS |
Ignition #2: | | Pink/Lt.Green | IGNITION SWITCH HARNESS |
Ignition #3: | | Dk. Blue | IGNITION SWITCH HARNESS |
Accessory: | | Pink / YELLOW (16 awg) & Pink / YELLOW (14 awg) | IGNITION SWITCH HARNESS |
Brake Light: | | WHITE/ Tan (+) | Above the brake pedal switch |
Tach Signal: | | DK. blue/Gray | Found at Power Control Module (PCM)* * |
Parking Lights: | | WHITE/ Lt. Green (-) | Found at the Headlight Switch* * * |
Headlights: | | | |
Diesel Glow Plug: | | | |
Clutch Bypass Wire: | | | |
Notes: | | * Many Of These Vehicles Are Equipped With A Transponder (Even If The Key Is Black). Use Universal Alarm Bypass Module Part Numner 2x402 Where X Can Be Any Number. ** PCM found on the passenger side of the firewall. *** The parking lights are negative trigger through a 2.7K ohm resistor. **** A negative trigger using 420 Ohm resistor will disarm the alarm. A negative trigger using a 2k Ohm resistor will arm the alarm. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | Red (+) | IGNITION SWITCH HARNESS |
OEM Alarm Disarm: | | PURPLE / Lt. Blue (-) | Drivers Kick Panel, Resistance based* * * * |
Dome Lights/Superv: | | See Note Below***** | See Note Below***** |
OEM Horn: | | Dk.GREEN/ Purple (-) | Steering Column |
Power Lock: | | PURPLE / Green (-) | See Note Below****** |
Power Unlock: | | Single wire (-) | See Note Below****** |
Trunk Release: | | | |
Alarm Input Wire: | | See Note Below***** | See Note Below***** |
Notes: | | ***** Separate Triggers For Each Door. The door pin wires are located in the drivers kick panel for the both left doors and The door trigger wires for the passengers door are found in the passengers kick panel. The Driver's Door Trigger Is Purple (-). The Left Rear Door Trigger Is PURPLE / Orange(-). The Passenger Front Door Trigger Is PURPLE / White (-) And the Passenger Rear Door Trigger Is Purple / YELLOW (-). Diode Isolate Each Wire For Alarm Trigger With The Bands Facing Away From The Alarm/Remote Start Module. Use Only One Trigger For Dome Light Supervision. ****** Single Wire Door Lock System See Note #211. The door lock wire is located in the drivers kick panel. Lock is a Negative Trigger Through a 800 Ohm resistor. Unlock is Negative Trigger through a 340 ohm resistor. |
2005 Toyota Corolla S
1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
You might have to use a different value resistor than that listed above for the parking lights. I did a truck like this about a month ago and the wiring diagram I used was from
www.bulldogsecuity.com and it had a 249ohm resistor listed ( I used a 250ohm resistor and it worked ).
I just had a tech brief sent to me one these trucks from B&B Electonics. If this is a diesel pickup then there could be issues. I'll snoop around for this buried document.
