2004 infinity g35 coupe alarm wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=44431
Printed Date: May 05, 2024 at 4:48 AM
Topic: 2004 infinity g35 coupe alarm wiring
Posted By: ksingh
Subject: 2004 infinity g35 coupe alarm wiring
Date Posted: December 04, 2004 at 4:22 PM
hey what up guys i am doing an alarm in this vehicle tomorrow sunday and i would like to know if anyone has the wiring schematic on this vehicle and can post it i would appreciate it . also please help me out with as much info as possible on this vehicle because its the first infinity i will be doing and i have it have it done by the end of the day no time for mistakes thanks guys ------------- Kenny
Posted By: mxxmikexx
Date Posted: December 04, 2004 at 4:51 PM
DIRECTWIRE™ WIRING INFORMATION - INFINITI / G35 COUPE / 2004 / Remote Start
[PRINT THIS PAGE]
12volts WHITE/ blue + ignition harness
Starter RED / white or WHITE/ red + ignition harness
Second Starter WHITE/ green + ignition harness
Ignition BLACK/ red + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory WHITE/ black + ignition harness
Second Accessory N/A
Keysense BLACK/ pink + ignition harness
Power Lock yellow - driver door module in door
Notes: These are the driver door key cylinder wires. Meter the wires while turning the key in the driver door.
Power Unlock lt. blue - driver door module in door
Notes: These are the driver door key cylinder wires. Meter the wires while turning the key in the driver door. Unlock requires a double pulse.
Lock Motor purple 5wi 16 pin plug, pin 30 at BCM
Notes: The BCM (Body Control Module) is in the driver kick panel, it has four white plugs and one brown plug.
Unlock Motor yellow 5wi 16 pin plug, pin 23 at BCM
Parking Lights+ RED / blue + driver kick, harness to rear
Parking Lights- N/A
Hazards GREEN/ red - brown plug, pin 61 at BCM
Turn Signal(L) GREEN / WHITE + 16 pin plug, pin 22 at BCM
Turn Signal(R) PURPLE / white + 16 pin plug, pin 21 at BCM
Reverse Light PURPLE / orange + driver kick, harness to rear
Door Trigger yellow (L), pink (R) - white 12 pin plug at BCM
Notes: The driver door trigger is yellow in pin 14, and the passenger door is pink in pin 10. Use both wires and diode isolate each.
Dome Supervision comes on with unlock
Trunk/Hatch Pin RED / white - 12 pin plug, pin 18 at BCM
Hood Pin lt. GREEN/ black - pin switch under hood
Trunk/Hatch Release pink - brown plug, pin 76 at BCM
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock
Tachometer NOT black or WHITE/ blue ac any ignition coil
Wait to start N/A
Brake Wire pink/blue + brake pedal switch
Parking Brake lt. GREEN/ black - parking brake switch
Horn Trigger GREEN/ black - steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 556U or 555U
Notes: N/A
