toyota sienna 1998
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=44668
Printed Date: June 16, 2024 at 10:59 PM
Topic: toyota sienna 1998
Posted By: madBedex
Subject: toyota sienna 1998
Date Posted: December 07, 2004 at 7:33 PM
 Hi!
 Any help would be greatly appreciated.
I installed an alarm on that van, everything is fine.But ,the powerdoor locks  when you press  lock button on the remote, it works fine ,but, the unlock  don't . I don't know if it's double pulse unlock or not.
Please give an idea.
madbedex
Posted By: daniel2002p
Date Posted: December 07, 2004 at 11:20 PM
which wire did you use to unlock, you need this one:
Power Lock blue/white   -  passenger kick panel
Power Unlock blue / YELLOW   -  passenger kick panel
NOTE:  they will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door itself.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: hagmanti
Date Posted: December 07, 2004 at 11:30 PM
Did you hook unlock to both Blue / YELLOW and Blue/Red and diode isolate those two? (Stripes towards neg unlock wire?)
(I have conflicting info-- perhaps Blu/Red & Brn/Red? Which sounds more familiar to me...)
Hope this helps,
Me
Posted By: madBedex
Date Posted: December 08, 2004 at 5:07 AM
I found 2 wires blue/red & blue.I think blue/red might be the child lock, but,the blue wire which i probed,i used the key to the door cylinder,so, when i turn it to lock,it don't nothin" and turn it to unlock, it show ground & stay ground.I really don't know if it's the right one.
It's 4 a toyota sienna 1998.
madbedex
Date Posted: December 08, 2004 at 6:24 AM
the blue wire is then your child lock wire.
    1.8L VVT-i I-4
