Viper 791 Starter Kill?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=44874
Printed Date: May 21, 2026 at 12:10 PM
Topic: Viper 791 Starter Kill?
Posted By: brentswanton
Subject: Viper 791 Starter Kill?
Date Posted: December 10, 2004 at 9:01 AM
Im installing a viper 791 in a 04 Tacoma and Im a little confused  with the starter kill.  Any help is appreciated.
On the Primary H1 harness there is a orange wire that may be wired to an optional kill relay.
But on another harness you have a purple and a  green wire that hook to the stater wire and to the key side of the starter wire.   I assume you cut the stater wire and hook the purple wire to the starter side and the green to the key side but what about the orange wire on the other harness???
Also on the remote start H3 harness am I suppose to use the blue/white wire to bypass the shock sensor when remote starting or does the sensor bypass by itself??
Thanks Brent
Posted By: hagmanti
Date Posted: December 10, 2004 at 9:55 AM
The purple and green do starter kill. The orange wire is for if you wanted to hook up your own starter kill (say you wanted to also shut off the fuel pump in another place in the car, to make it even harder to get around...)
The sensor that it comes w/ is automagically bypassed during remote starts.
Me
Date Posted: December 10, 2004 at 1:52 PM
Thanks for the Help
