2003 Dodge Dakota door trigger wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=44907
Printed Date: May 21, 2026 at 1:22 AM
Topic: 2003 Dodge Dakota door trigger wire
Posted By: sdg708
Subject: 2003 Dodge Dakota door trigger wire
Date Posted: December 10, 2004 at 7:25 PM
I am having trouble finding it. Anyone know where this is located and what color? It has an auto dimmer so I cannot use the dome light.
Posted By: BNLUIS
Date Posted: December 10, 2004 at 8:08 PM
 *2 The Central Timer Module is in the driver kick panel.  *3 The driver door trigger is tan in connector 2, pin 15. The passenger door trigger (and rears on the 4dr) is tan/red in connector 2, pin 13. Use both and diode isolate each. See directfax document #1076 for wiring information.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
