2005 Kia Sorento, Prestige Platinum 996a
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=44918
Printed Date: May 21, 2026 at 6:58 AM
Topic: 2005 Kia Sorento, Prestige Platinum 996a
Posted By: Trav3D1
Subject: 2005 Kia Sorento, Prestige Platinum 996a
Date Posted: December 10, 2004 at 9:48 PM
Installed a Prestige Platinum 996a on a 2005 Kia Sorento.  Everything is working just fine with the exception of the remote start.  I have conflicting information about the tach wire.  DEI is indicating green / black and DesignTech is indicating a red wire, both located at the top of the engine block.
Please confirm the wire color and location.
Thanks in advance
Trav
Posted By: hagmanti
Date Posted: December 10, 2004 at 11:20 PM
Confirm it yourself!
Seriously, put a DMM across 12V and each of those wires. Start the car. Look for an AC voltage (around .5 - 5ishV) that varies w/ engine speed.
(sometimes need to go across ground and the putative tach wire)
That's all tach is...
   Me
Posted By: Trav3D1
Date Posted: December 11, 2004 at 7:09 AM
I'm much smarter than that my friend.  I have been doing this for 7+ years, and I know how to test a tach with a DMM.  Could have been a long day and I'm starting fresh on the vehicle this morning.
Thanks again
Trav
Posted By: DanDan
Date Posted: December 11, 2004 at 8:07 AM
Tach wire is behing the instrument cluster, the color is GREEN/ black. It is the connector closest to the middle of the vehicle. Cluster or ECM, 28 pin plug, pin 5.
DanDan
Posted By: hagmanti
Date Posted: December 11, 2004 at 10:26 PM
My apologies-- I thought you were just asking which of two wires that you were currently looking at was tach, and didn't know how to measure tach. If I'd looked at your profile, I would have known better-- I just assumed.
Anyway, hope you got the car out the door,
Me
Posted By: Trav3D1
Date Posted: December 13, 2004 at 7:48 AM
Not a problem hagmanti.
I did successfully complete the install.  I was primarily seeking assistance for a different location to find the wire.  I don't particularly like dismanteling new cars.  This Kia only had 400 miles on it, and I just like to take an extra precaution when working on cars that I have not worked on before, and more importantly, NEW cars.
Thanks for all the help, I ended up pulling the instrument cluster out and found the wire.
Trav
