04 nissan frontier wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45021
Printed Date: April 07, 2026 at 12:36 AM
Topic: 04 nissan frontier wiring diagram
Posted By: richliz93
Subject: 04 nissan frontier wiring diagram
Date Posted: December 12, 2004 at 11:33 AM
need wiring diagram for 04 nissan frontier
Posted By: hagmanti
Date Posted: December 12, 2004 at 9:28 PM
Transponder anti-theft
Batt - Green (+) ign harness
Ign1 - BLACK/ white (+) - "
Ign2 - RED / yellow (+) - "
Acc1 - white (+) - "
Str1 - BLACK / YELLOW (+) - "
Str2 - GREEN/ YELLOW (+) - "
Horn - Light GREEN/ red (-) - at SECM*
NSS - yellow (-) - At relay center underhood
Tach - Pink/blue (AC) - at ign coil (may also be found as black wire pin 2 @ the ECM behind the center dash
VSS - GREEN/ black (AC) - in harness in passenger kick
ParkLights - blue/red (+) - at light switch
BrkeLights - BROWN / Red (+) - at brake switch above pedal
RevrLights - Yellow/Red (+) - in large junction plug in pass kcik
Key sense - WHITE/ green (+) - ign switch harness or at SECM*
All door trigger - RED / black (-) - driver's kick
Door triggers - LF GREEN/ red RF RED / Black LR RED / Yellow, RR RED / yellow (-) - @SECM*
Hood trigger - BLACK/ pink (-) - @SECM*
Arms & Disarms w/ locks
Unlock - Yellow/Red (-) - @SECM*
Lock - Yellow (-) - @SECM
Driv Mtrl Unlock - GREEN / WHITE (+) - DKP
Driv Mtr Lock - Blue (+) - DKP
Wipers - WHITE/ red (-) - @wiper switch
Headlights - red (-) - @SECM*
* Smart Entrance Control Module is located below driver's dash to right of steering column
Always check all wires that you hook to w/ a DMM!
Me
Posted By: depressd
Date Posted: January 04, 2005 at 10:38 AM
Do all the 04 frontiers have the transponder? Is this for factory equipped alarm systems only?
Posted By: KarTuneMan
Date Posted: January 05, 2005 at 6:40 PM
