01 CIvic, Viper 791
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45738
Printed Date: May 03, 2024 at 4:29 PM
Topic: 01 CIvic, Viper 791
Posted By: aznmikex215
Subject: 01 CIvic, Viper 791
Date Posted: December 22, 2004 at 12:27 AM
Hello,
Im pretty new to installing alarms. I have wired some audio and thats all fine an dandy. This is my first car alarm install attempt. I have some confusion about a few wires, bsically i dont know if i need them or where to hook them to. please help me! I dont need any fancy window rolling or trunk releasing. I just want the alarm features + remote start. Just the basics really.
Car: 2001 civic EX coupe AUTOMATIC
Alarm: Viper 791XV
* I already have a bypass module
Listed below are the wires that i dont have a clue about. I dont know if i need them, i dont know where they go if i do. please help!
PRIMARY HARNESS (H1) QUESTIONS:
Orange (ground when armed output)
WHITE/ Blue (-) Activation input
Violet (+) Door trigger input
SECONDARY HARNESS (H2) QUESTIONS:
BLUE (-) 2nd unlock output
REMOTE SECONDARY HARNESS (H3) 5 pin connector:
BLACK/ White nuetral safety switch
Blue/White (-) 200 mA 2nd status/defogger
DOOR LOCK HARNESS (3 PIN CONNECTOR)
Green (-) lock (+) unlock
BLUE (+) unlock (-) lock
REMOTE START HARNESS
Blue (-) status output
Orange (-) 200mA 2nd accesory output
Purple (-) 200 mA start output
please help me if im forgetting anything. Any wires i didnt list, i pretty much am sure where they go or that i dont need them.
| 12V|white |+ |ignition harness |
| STARTER|BLACK/ white |+ |ignition harness |
| IGNITION|BLACK / YELLOW |+ |ignition harness |
| ACCESSORY|BLACK/ red |+ |ignition harness |
| SECOND ACCESSORY|WHITE/ red |+ |ignition harness |
| POWER LOCK|WHITE/ blue |- |gray plug above drivers kick|
| POWER UNLOCK|WHITE/ green |- |gray plug above drivers kick|
| LOCK MOTOR|yellow/black | |back of the fusebox *3 |
| UNLOCK MOTOR|YELLOW /GREEN | |back of the fusebox *3 |
| DISARM DEFEAT|yellow | |back of the fusebox *3 |
| PARKING LIGHTS +|RED / black | |back of the fusebox |
| PARKING LIGHTS -|blue | |factory alarm plug *1 |
| HEADLIGHTS|blue/red |- |headlight switch |
| DOOR TRIGGER|*2 |- |factory alarm plug *1 |
| DOME SUPERVISION|comes on with unlock| | |
| TRUNK/HATCH PIN|red |- |factory alarm plug *1 |
| TACHOMETER|blue | |test connector *4 |
| SPEED SENSE|WHITE/ green | |PCM *5 |
| BRAKE WIRE|WHITE/ black |+ |brake pedal switch |
| HORN TRIGGER|orange |- |steering column |
| WIPERS|blue (L), blu/yel(H)|- |steering column |
| LF WINDOW UP/DN|RED / blk - RED / yel |A |drivers window switch |
| RF WINDOW UP/DN|blu/red - blu/wht |A |drivers kick panel |
| LR WINDOW UP/DN|brn/wht - brown |A |drivers kick panel |
| RR WINDOW UP/DN|blu/org - brn/yel |A |drivers kick panel |
| RADIO 12V|WHITE/ red |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/red |+ |radio |
| RADIO ILLUMINATE|RED / black |+ |radio |
| POWER ANTENNA| | | |
| LF SPEAKER|grn/blk - lt green | |radio |
| RF SPEAKER|grn/yel - gry/red | |radio |
| LR SPEAKER|blu/wht - blu/blk | |radio |
| RR SPEAKER|pink - blu/yel | |radio |
Notes:
NOTE: This vehicle has an immobilizer system *1 The factory alarm plug is a green plug above the drivers kick panel. *2 The drivers door trigger is green, front passenger door trigger is lt. GREEN/ red, and the rear door trigger is GREEN / WHITE. *3 In the top left plug. *4 It is a 2 pin plug to the passenger side of the battery. *5 The PCM is behind the glove box. The vss is in a connector A (31 pins), pin 18. The vss is also blue/white at the cruise control module to the left of the steering column.
Posted By: profuse007
Date Posted: December 22, 2004 at 10:20 AM
youll need these wires:
Blue (-) status output - to activate ur bypass
BLACK/ White nuetral safety switch - ground it
DOOR LOCK HARNESS (3 PIN CONNECTOR)(the diagram is screw up) dont worry about the (+)
Green (-) lock
BLUE (-) unlock
------------- Houston,TX
Date Posted: December 22, 2004 at 11:25 AM
Hey thanks man. i did a little more reseach and found that stuff out. you just confirmed it for me. thanks again!
Date Posted: December 22, 2004 at 4:37 PM
What would i use the BLUE/WHITE (-) 200mA 2nd status / defogger for? How would i hook it up to my defogger?
Date Posted: December 22, 2004 at 5:07 PM
use a relay to trigger the defogger.
85-status
86-ign or 12volt constant
30- -/+ input
87- the defogger wire
Date Posted: December 23, 2004 at 6:57 PM
for the RELAY SATELLITE BOX:
Are the only wires i need to use for a basic install + immobolizer the 8 heavy guage wires and the one blue wire ?
Date Posted: December 31, 2004 at 3:20 PM
Hey i just wanna thank you guys for all your help! install took about 3 hours or so. Everything is nicely loomed and taped up. ALl features work!
THanks again!
Date Posted: December 31, 2004 at 4:41 PM
good to hear it works out well.
