Remote start not working
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46405
Printed Date: May 19, 2024 at 1:41 AM
Topic: Remote start not working
Posted By: 6tre_daddy
Subject: Remote start not working
Date Posted: December 30, 2004 at 4:52 PM
I am installing a Python 1500 ESP on a 2000 Nissan Altima. My friend told me I needed a 555U Bypass in order for the remote start to work. Now this box requires a key inside it, which I think sends a signal to the car in order for it to start. So I went to the dealer and had them make me an extra key for like $100 bucks, because it has a blue chip in it. Everything on the alarm works fine now except the remote start!  When I try to activate it, the dash lights come on for a few seconds and then it stops. And it trys again on its own, but then that's it. If anyone has had this problem and can share their experience or any possible solutions, I would be GREATFUL!  Or possibly a wirring diagram so I can double check my connections.
Posted By: KarTuneMan
Date Posted: December 30, 2004 at 5:48 PM
12volts WHITE/ red   +  ignition harness
Starter BLACK / YELLOW   +  ignition harness
Second Starter BLACK/ blue   +  ignition harness
Ignition BLACK/ red   +  ignition harness
Second Ignition
Third Ignition
Accessory BLACK/ pink   +  ignition harness
Second Accessory WHITE/ blue   +  ignition harness
Keysense
Power Lock gray   -  smart entrance control
Notes: The smart entrance control unit is located to the right of the steering column. It is black or blue in color.
Power Unlock purple   -  smart entrance control
Lock Motor RED / blue    smart entrance control
Unlock Motor yellow    smart entrance control
Parking Lights+ RED / blue    steering column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger RED / white   -  drivers kick panel or SECU
Notes: To avoid dome light delay use RED / green for the driver door, red for the front passenger door, and RED / black for the rear doors. All 3 three wires are located at the smart entrance control unit. Must diode isolate each.
Dome Supervision use door trigger
Trunk/Hatch Pin red or RED / blue   -  light in trunk
Hood Pin pink/black   -  smart entrance control
Trunk/Hatch Release ORANGE / black   -  smart entrance control
Power Sliding Door
Factory Alarm Arm lt GREEN/ red   -  smart entrance control
Factory Alarm Disarm GREEN/ YELLOW   -  smart entrance control
Disarm No Unlock
Tachometer WHITE/ black    6 pin plug at distributor
Wait to start
Brake Wire RED / green   +  brake pedal switch
Parking Brake
Horn Trigger brown or grn/yel   -  steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
posted_image
Immobilizer Bypass Module:Required: YesType: TransponderPart #: 556
Date Posted: December 30, 2004 at 5:55 PM
The only thing I would ask....is did you wire up the second starter?
Where did you get the tach....
Posted By: kevindanielk
Date Posted: January 01, 2005 at 3:52 AM
Try placing a working key in the ignition but don't turn it on. Then, try to remote start the car while this key is in the cylinder. If the car starts, the key in the 555u is not sending the signal to the immobilizer to allow it to crank and start. This could be due to a wiring problem with the 555u or the key in it doesn't function properly. Remove the key in the 555u and see if it will start the car the regular way or double check your 555u wiring to make sure it is getting ground on to blue wire from the alarm when you try to remote start. Also, make sure the antenna ring is securely around the edge of the key cylinder. They slip out sometimes.
If the car still fails to start, you might want to check your wiring on your starter disable relay. You must wire the large purple wire from the heavy duty satellite relay, which is the starter crank signal, to the starter side of the starter disable relay. You might have it wired to the key side of this wire. When the R/S tries to crank, it encounters the disable relay and can't crank the starter. It then shuts off and comes on to retry again without success. I have mistakenly wired a few R/S this way in the past and learned my lesson. Hope this helps.
Posted By: MJA1962
Date Posted: January 01, 2005 at 8:37 AM
Good advice from kevindanielk.  Another quick thing to check is the hood pin switch.  If it's grounding out, or you're testing the starter with the hood up, you would get the symptoms you describe.
-Michael
