00 Sierra Keyless Entry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46484
Printed Date: June 09, 2024 at 10:57 AM
Topic: 00 Sierra Keyless Entry
Posted By: bcw757
Subject: 00 Sierra Keyless Entry
Date Posted: December 31, 2004 at 12:24 PM
Ok, I got a keyless entry/remote starter for my truck, and went about hooking it up last night. (Thanks for all the help the guys gave to me on the other post) My remote starter works perfect on the truck, however when hooking up the keyless entry portion, I found that it was giving a negative read when I need a positive. Ok, now I know I'm going to have to use a relay for this, but someone needs to break it down in lamens terms what I need to do for this particular truck. Any help is always appreciated Thanks B
Posted By: TooDark
Date Posted: December 31, 2004 at 1:20 PM
OK here we go, I hope you have 2 relays if so here is the wiring. take the negetive pulse from the remote starter and wire that into 86 of the relay, 87 and 85 need to be wired into a fused 12V and then run the 30 to the 12V needed to operate your 12V door locks.
Posted By: electra
Date Posted: December 31, 2004 at 1:42 PM
Hey bcw757, sorry to butt in but I'm doing a remote starter install on the same truck, it not mine, but I have a dumb question for you, with regards to the factory security system interface how sis you wire yours? I guess I don't understand how the security system operates on this truck.
Posted By: TooDark
Date Posted: December 31, 2004 at 1:57 PM
should be a green wire in DKP coming from driver door and it is a neg disarm
Posted By: electra
Date Posted: December 31, 2004 at 2:06 PM
Thanks, now the part I'm unclear on is the re-arming for this truck, specificlly, does it automaticlly rearm with a doorlock signal? My remote starter will disarm before remote starting but I want it to rearm after.
Posted By: bcw757
Date Posted: December 31, 2004 at 3:16 PM
I bought a PL DATA GM Passlock II bypass. Comes with 4 wires (Red, Violet, Brown, Black) Red = 12v Black = Ground Brown = Ground when running (hooks up to your remote starter) Violet = Taps into the Violet Wire On the diagnostics plug, located underneath the dash, above the brake Takes 2 minutes to hook up and program, great little tool.
Posted By: bcw757
Posted By: bcw757
Date Posted: January 18, 2005 at 2:56 PM
Ok, got my relays, and wired everything up, and I'm getting nothing. I can hear the relay click, and voltages check out, but when I hook it up to the light blue wire in the bcm (lock) the it doesn't lock. hmmmm??? Any suggestions? I've searched through a few other posts, and everyone says this is a simple 5 minute hookup, well it's been an hour now with a volt meter, and patience is running thin....
