VALET 554
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47046
Printed Date: May 28, 2024 at 9:00 PM
Topic: VALET 554
Posted By: mbs17
Subject: VALET 554
Date Posted: January 06, 2005 at 11:01 AM
Just got a Valet 554, need to install on a 2005 tundra double cab. Do i need anything else for install? Also, how difficult is it to install, or should I pay to have it done?(never installed one before) What can i expect to pay if i dont install it? thanks
Posted By: snguyen
Date Posted: January 06, 2005 at 11:15 AM
Toyota | Tundra Double Cab | 2005 |
Remote Starter Wiring Colors and Notes | Function | | Vehicle Color | Location | Start: | | BLACK/ White (+) | Ignition switch harness | Ignition #1: | | BLACK/ Red (+) | Ignition switch harness | Ignition #2: | | BLACK / YELLOW (+) | Ignition switch harness | Ignition #3: | | N/A | | Accessory: | | Pink (+) | Ignition switch harness | Brake Light: | | GREEN / WHITE or WHITE/ red(+) | Brake pedal switch | Tach Signal: | | Black or Blue/White (AC) | ECM 2nd plug from right | Parking Lights: | | Green (+) | Drivers kick panel | Headlights: | | N/A | | Diesel Glow Plug: | | N/A | | Clutch Bypass Wire: | | N/A | | Notes: | | |
Alarm and Keyless Entry Wiring Colors and Notes | Function | | Vehicle Color | Location | Constant +12 Volts: | | WHITE/ Red or White (+) | Ignition switch harness | OEM Alarm Disarm: | | YELLOW /GREEN(-) | Ign. Switch harness (keysense wire) | Dome Lights/Superv: | | N/a | | OEM Horn: | | BLACK / YELLOW (-) | Steering column harness | Power Lock: | | Blue/red (5) | Drivers kick Reverse polarity | Power Unlock: | | RED / black(5) | drivers kick Reverse polarity | Trunk Release: | | N/A | | Alarm Input Wire: | | N/a | | Notes: | | ** See Note #201 Negative Trigger Door Locks |
Posted By: gtchida
Date Posted: January 06, 2005 at 1:35 PM
If this is your first alarm install, it will be a challenge. Depending on what features you install will determine how much more you'll need (wiring, relays, etc). Gary
Posted By: gus1
Date Posted: January 06, 2005 at 5:21 PM
And, if you can figure out how to set the clock on the damn remote without wanting to throw it at the wall.... let me know. I've got another installer at one of our other shops that would lovetoknow (myself included)
Gus
------------- Wherever I go, that is where I end up......
Posted By: stevent
Date Posted: January 06, 2005 at 5:29 PM
GUS1 Hold down the F key for five seconds and the remote will enter the menu to change the clock settings.
Posted By: gus1
Date Posted: January 06, 2005 at 6:05 PM
Really? I thought it was more involved than that. I seem to remember a rather annoying sequence, follwed by accidentally hitting the wrong button and exiting the clock menu without doing anything, all accompanied by beeping. Hafta try again when we get some more of them in.
Gus
Posted By: kgerry
Date Posted: January 07, 2005 at 9:06 AM
nope, thats the easiest feature ( among the 3247 available features ) to program on these units... press F button 5 secs and it goes into adjust clock mode
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: gus1
Date Posted: January 07, 2005 at 10:09 AM
Cool. I just remember sitting in Clarion training, and as Sanjay sent around the remote for the SR5000, and got to my table, the head installer in our Wpg. store(Ken Gingles) just goes " $5 if you can set the clock on it". Niether of us could figure it out, however the beeping and such was rather entertaining, and, as Sanjay put it "There's always one in every seminar"
Gus
