2000 Grand Prix PK3
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47110
Printed Date: May 29, 2024 at 6:59 AM
Topic: 2000 Grand Prix PK3
Posted By: homey88
Subject: 2000 Grand Prix PK3
Date Posted: January 07, 2005 at 12:32 AM
I have a issue well maybe! Im using a jbs 791 Learning bypass/transponder and every thing works, car starts and works good but the security light stays on. Even after inserting key and turning to the "on" position and stays on untill i turn off the car. If i restart with key no light, only with remote start. Any ideas!!!!!
------------- Brian
Posted By: italnpimp59
Date Posted: January 07, 2005 at 12:55 AM
did you pulse the keysense wire? that could be the problem
Posted By: homey88
Date Posted: January 07, 2005 at 1:06 AM
This is how I hooked it up, except i didnt use a bulldog starter, i have a Crimestopper EZ90 ------------- Brian
Date Posted: January 07, 2005 at 1:07 AM
what alarm do you have, im pretty sure you have to power up the keysense wire
Posted By: homey88
Date Posted: January 07, 2005 at 1:27 AM
I'm not sure if i know what a keysense wire is? at least at the moment anyway, the car has factory alarm/keyless and i put in the crimestopper EZ90/RS900 and the 791 bypass. at the moment the factory alarm is deactivated im going to go back under and hook up the arm/disarm function now that i found the wire location.
------------- Brian
Posted By: homey88
Date Posted: January 07, 2005 at 9:03 PM
Any Ideas!!!!!!!!!!!
------------- Brian
Posted By: jrilla
Date Posted: January 07, 2005 at 9:32 PM
I dont know if you need to hook it up or not, but the key sense wire is a lt.Green wire in the three pin connector with the starter wire.
------------- J Rilla
Owner/Installer
Posted By: homey88
Date Posted: January 08, 2005 at 12:42 AM
Ok one more ? , I dont have a 3pin connector i have a 8pim on the bypass and a 12pin on the starter. or is this 3pin ion the car somewhere?
------------- Brian
Posted By: jrilla
Date Posted: January 08, 2005 at 9:24 AM
OOPS, I was looking at the 2004 Grand Prix. How many Lt. Green wires do you have? Just test them. It will be (-) when key is inderted.
Owner/Installer
Posted By: homey88
Date Posted: January 09, 2005 at 12:50 AM
is this green wire in part of the car? ------------- Brian
Posted By: homey88
Date Posted: January 09, 2005 at 8:21 PM
please help!
------------- Brian
Posted By: Craig3708
Date Posted: January 09, 2005 at 9:56 PM
These learning modules are a little tricky on the PK3. If I were you I would recheck all connections, (grounds are very important). If this module needs a ground when running wire MAKE SURE ITS CONNECTED to the R/S. Reprogram the bypass module. Do the light come on if you leave the key in the ignition while remote starting??? Craig.
Posted By: homey88
Date Posted: January 10, 2005 at 1:02 AM
no it goes out! ------------- Brian
Date Posted: January 10, 2005 at 8:43 AM
Homey, do you have the orange wire from the bypass module hooked to a (-) GROUND when running source?? Also if this transponder has a pre-fab loop, cut it off and peel back enough wire to make two loops around the ignition. When you try to remote start the car make sure the other factory key is not in the car. From what you are telling me, your bypass isn't working at all, because the PK3 system will not read two keys (codes) at the same time, so if the car started remotely with the key in the ignition the other in the box dider't do its job. Craig.
Posted By: homey88
Date Posted: January 10, 2005 at 12:37 PM
The bypass works, car starts everytime it just leaves the security light on and dosent go out unless i turn off and restart with key. the orenge is hooked to constant ground as per instructons, red to crank wire and blue to ignition ground(bypass output wire on starter). what is a keysense wire, where is it, on the car somebody said i have to hook it up but im not sure where and what it is. Thanks for the help.
------------- Brian
Date Posted: January 10, 2005 at 3:47 PM
I have never had to hook up a keysence wire on a PK3 system, but what this wire does is is sends a (-) negitive signal to the ECM when the key is in the ignition. This wire is Light Green in the ignition harness, and will show (-) when the key is in the ignition. You need to hook this up to a negitive output when the Remote Start is activated. (ground out when running). Craig.
