diode isolate confusion/remote start only
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47965
Printed Date: June 11, 2024 at 7:46 AM
Topic: diode isolate confusion/remote start only
Posted By: repmud
Subject: diode isolate confusion/remote start only
Date Posted: January 17, 2005 at 8:07 PM
I just finished up installing a compustar rt4200 on my 02 cavalier. I haven't powered it up yet because I am confused on the door trigger diode isolate issue. As far I can tell diode isolation is for alarms only? However, I am installing this on a manual trans car and it needs to read the door triggers in order to operate properly. There are 2 seperate door triggers in the car and one - input to the r/s. What do I do?
Thanks.
Posted By: Jschult3
Date Posted: January 17, 2005 at 8:11 PM
R U confused about which end the striped side goes or are you confused about where to place them? ------------- Jeff
Always Verify Wire information before Connecting! Just a Darn Good DIY'R
Posted By: repmud
Date Posted: January 17, 2005 at 9:07 PM
I am confused if I need them or not and if the door/doors are opened if that will trigger the r/s not to start like it's supposed to.
Posted By: KarTuneMan
Date Posted: January 17, 2005 at 9:12 PM
Yes and it should also trigger the alarm!
Posted By: repmud
Date Posted: January 17, 2005 at 9:15 PM
ok, thanks for the help and quick response guys!
Posted By: repmud
Date Posted: January 17, 2005 at 10:09 PM
do i have to do the trunk too? I have it hooked to the - on the light.
Posted By: Velocity Motors
Date Posted: January 17, 2005 at 10:13 PM
No you don't. The trunk has it's own trigger wire so you don't have to diode isolate this wire.
------------- Jeff
Posted By: repmud
Date Posted: January 17, 2005 at 10:17 PM
Thanks again guys.
