2004 Silverado Problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48087
Printed Date: May 09, 2024 at 10:14 PM
Topic: 2004 Silverado Problem
Posted By: Memphisman
Subject: 2004 Silverado Problem
Date Posted: January 19, 2005 at 7:10 AM
I recently installed a Crimestopper RS830 and a GMDL-BP in a 2004 Silverado and all works fine except that it will start up and run for only 40 seconds to a couple of minutes then shut off. I have it running in tach mode and when tested, the tach signal seems to be good and the security light is going out. Any ideas?
Posted By: kgerry
Date Posted: January 19, 2005 at 8:58 AM
IF IT WERE A pASSLOCK ISSUE IT WOULD NOT RUN FOR A MINUTE OR TWO....( oops sorry ) i would relearn tach when its warm and see if that changes anything... does the Crimestopper give you shutdown diagnostics like some of the other brands (DEI) do? if so, what is that telling you shut the unit down?
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: sroth140
Date Posted: January 19, 2005 at 10:51 AM
what wire are you using for the tach? i think on those year trucks you can still pull the gauge cluster out and use the only white wire back there. be sure to test it, but on 99+ chevy trucks you can grab it right there.
------------- MECP certified installer
Date Posted: January 19, 2005 at 6:28 PM
I'm using the odd color on one of the fuel injectors.
Posted By: johnnydi77
Date Posted: January 19, 2005 at 7:45 PM
That starter may not like the one cylider setting a injector wire supplies. Try the one behind the cluster, it's very easy to get to and is a solid 4 cylider setting.
------------- John J. DiStefano Jr.
Posted By: KarTuneMan
Date Posted: January 19, 2005 at 7:57 PM
Get your tach from the PCM under the hood. White wire
Posted By: secureauto
Date Posted: January 19, 2005 at 11:18 PM
Here's some info from DEI:
Tachometer white (ac) instrument cluster, pin A5 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug, pin 10.
For tach can also go to any of the ignition coils or injectors and use the wire that is NOT pink, black, or brown.
------------- ASE Certified
Posted By: sroth140
Date Posted: January 19, 2005 at 11:43 PM
fine dont listen to me... even though DEI told me to go behind the cluster.
Posted By: extreme1
Date Posted: January 20, 2005 at 12:17 AM
I also use the whit wire at the instrument panel.
------------- Shaughn Murley
Visions Electronics
Red Deer, Alberta
